SpannerHead
Associate Columns By Name
I got something to work here
Solved: Automatically plot associated columns - JMP User Community
but I'm pretty sure it's unnecessarily cumbersome.  I have column names ending with the letter H (High) that I need to associate with column names that otherwise match but end with the letter L (Low).  I can create an associative array with the column names having the final character removed.  Snookered as to what to do next?
names default to here(1);
colList = dt << get column names( string );
for each({col,index}, colList,
	//colList[index] = substr(col,1,3)
	colList[index] = Left(col,Length(col)-1)
grps = associative array(colList)<<get keys;
For instance, VT123ABCH needs to plot against VT123ABCL and so forth.
Slán
SpannerHead
10 REPLIES 10
SpannerHead
Re: Associate Columns By Name
Great script and a lot simpler.  I tweaked it a bit to have all the plots in a "Compilation" window .
colNames = dt << get column names( continuous, string );
New Window( "Compilation",
	For Each( {col}, colNames,
		If(
			Starts With( col, "VT" ) & Contains(
				colNames,
				Substr( col, 1, Length( col ) - 1 ) || "H"
			Graph Builder(
				Size( 534, 456 ),
				Variables(
					X( As Column( col ) ),
					Y( As Column( Substr( col, 1, Length( col ) - 1 ) || "L" ) )
				Wrap( :LOT ),
				Elements(
					Points( X, Y, Legend( 1 ) ),
					Line Of Fit( X, Y, Legend( 3 ) )
Slán
SpannerHead
