SpannerHead
Associate Columns By Name
I got something to work here
Solved: Automatically plot associated columns - JMP User Community
but I'm pretty sure it's unnecessarily cumbersome.  I have column names ending with the letter H (High) that I need to associate with column names that otherwise match but end with the letter L (Low).  I can create an associative array with the column names having the final character removed.  Snookered as to what to do next?
names default to here(1);
dt = Current Data Table();
colList = dt << get column names( string );
for each({col,index}, colList,
	//colList[index] = substr(col,1,3)
	colList[index] = Left(col,Length(col)-1)
grps = associative array(colList)<<get keys;
For instance, VT123ABCH needs to plot against VT123ABCL and so forth.
Slán
SpannerHead
Re: Associate Columns By Name
Here is an example of how you might do what you want
dt =
// Open Data Table: semiconductor capability.jmp
// → Data Table( "semiconductor capability" )
Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
colNames = dt << get column names( continuous, string );
For Each( {col}, colNames,
	If( Ends With( col, "1" ) & Contains( colNames, Substr( col, 1, Length( col ) - 1 ) || "2" ),
		Graph Builder(
			Size( 534, 456 ),
			Show Control Panel( 0 ),
			Variables( X( As Column( col ) ), Y( As Column( Substr( col, 1, Length( col ) - 1 ) || "2" ) ) ),
			Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) )
10 REPLIES 10
Do the pairs always exist? Are there other columns in the table than these pairs? Are they in specific order?
Edit:
Can most likely be made much better depending on the real use case
dt = New Table("",
	New Column("VT123ABCH"),
	New Column("VT123ABCL")
collist = dt << get column names(string);
hcols = Filter Each({colname}, colList,
	Ends With(colname, "H");
aa = Associative Array();
For Each({hcolname}, hcols,
	lcolname = Left(hcolname, Length(hcolname) - 1) || "L";
	If(dt << Has Column(lcolname),
		aa[hcolname] = lcolname
Show(aa);
SpannerHead
Jarmo
Looks much tidier that what I had, however, I'm getting this error.
"Object 'Data Table' does not recognize the message 'Has Column'"
Slán
SpannerHead
That was added in JMP18
You can change it to Contains() and it should be fine most of the time
Contains(collist, lcolname)
SpannerHead
Jarmo
This is close but I notice that hcolname is empty, whereas lcolname has a value.  Do I need to establish hcolname as an object or list?
Slán
SpannerHead
hcols should contain a list of all columns which end with "H". This is then used in For Each and each if the items will be one by one used as hcolname. You can add debug prints to understand what is going on. Also, this definitely isn't the only way of doing this you could for example easily in a single loop.
SpannerHead
Jarmo
This gets me a little closer but the lcolname does not populate until the final value.
For Each({hcolname, index}, hcols,
	{lcolname, index}, hcols = Left(hcolname, Length(hcolname) - 1) || "L";
	If(dt << Contains(collist, lcolname),
Slán
SpannerHead
For me it seems to be working fine. You can change the example table to semiconductor capability and check for some numbers at the end
Names default to here(1);
	Ends With(colname, "1");
	lcolname = Left(hcolname, Length(hcolname) - 1) || "2";
Show(aa);
aa = ["ESM1" => "ESM2", "FST1" => "FST2", "INM1" => "INM2", "IVP1" => "IVP2", "NPN1" => "NPN2", "PBA1" => "PBA2", "PLG1" => "PLG2", "PLY1" => "PLY2", "PNP1" => "PNP2", "RES1" => "RES2", "RSP1" => "RSP2", "SIT1" => "SIT2", "VDP1" => "VDP2", "VPM1" => "VPM2"];
But you could also go a bit different route with a bit more configuration options
endchar1 = "1";
endchar2 = "2";
rgx_endchar1 = Eval Insert("(.+?)^endchar1^$");
For Each({colname}, collist,
	col_ptrn = Regex(colname, rgx_endchar1, "\1");
	If(!IsMissing(col_ptrn), // ends with H
		If(Contains(collist, col_ptrn || endchar2),
			aa[col_ptrn || endchar1] = col_ptrn || endchar2;
show(aa);
Both of these do return same results for me
SpannerHead
Jarmo
Oddness of JMP.  First one doesn't work, second one does, JMP 17 maybe?  Thanks for putting up with me.
Slán
SpannerHead
dt =
		Graph Builder(
			Size( 534, 456 ),
