Assign variable to table based on the contain of the table name.
I have multiple table that are open and need to assign variable based on a contain(DC1,DC2,DC3) of the table name. If table name contain DC1 assign dt1, if it Table name contain DC2 assign dt2....
Table 1: ABC_25C_DC1_2024
Table 2: ABC_25C_DC2_2024
Table 3: ABC_25C_DC3_2024
Here is the command line that i was try to work with.
tablelist = Get Data Table List() << get name;
If(Contains(Concat Items(tablelist), "DC1"),
dt2= XXXXXXXXX
Re: Assign variable to table based on the contain of the table name.
If you can be 100% sure about the names, then I would store them into a list
New Table("ABC_25C_DC1_2024");
New Table("ABC_25C_DC2_2024");
New Table("ABC_25C_DC3_2024");
dc_tables = {};
For Each({tablename}, tablelist,
	If(Starts With(tablename, "ABC_25C_DC"), // some pattern to catch correct tables
		Insert Into(dc_tables, Datatable(tablename));
You can then access them with dc_tables[1] and so on.
I don't think that provides any additional clarification to me, expect that you can capture the table "type" after last _. If you can capture table "type" from the end (after last _) you can use Associative Array (or still a list). You can use Word to capture the last part of name
str = "ABC_25C_DC1_2024";
last_part = Word(-1, str, "_");
Final idea would still be the same, find some way of getting references to your tables, store them into some data structure (list or associative array), get the tables from that data structure when needed using index (list) or key (associative array).
How do you open those tables? Could you create references during that process? I would also store those into a list instead of trying to use separate dt1, dt2, dt3... for them.
They are created by some other automated JMP script that I don't have access to.
dc_tables = {};
I hope this will clarify further of what I am trying to achieve.
