Assign a "bin" value based on odd or even value in another column
Created:
Sep 8, 2021 09:06 AM
| Last Modified: Jun 10, 2023 4:36 PM(3830 views)
Is it possible to assign a "bin" value based on the number being odd or even. The attached table already has a bin column but i am trying to split this pick list up and making every other part a different bin
txnelson beat me to it! Anyway, I attached my version of his solution using the mod function, assuming you wanted to do this by row number. Of course, you could use any other numeric value to spit by odd/even this way.
PICKLIST.jmp
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '416299' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '416299') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '416299') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
