Applying Neural Fit from one data table to a different one
Mar 21, 2025 01:29 PM(2046 views)
I have two tables of data from different sources. Both tables have the exact same set of column variables, but have different numbers of rows (one has 35 rows and the other has 150 rows).
I created a Neural Fit formula in JMP Standard for the larger dataset using 4 nodes and it resulted in a decent fit. I am now wanting to apply the exact formula created by the larger dataset to the smaller dataset.
The columns of data created by the large dataset look like this...
But when I copy the formulas into the smaller dataset then the results are broken...
I'm seem to be missing some sort of formatting or reference which is causing this error. Any suggestions on how to port over the larger table's Neural Fit formula to the smaller table?
How are you copying the columns over? Also do you need the separate formulas for hidden nodes as in have you tried the other formula saving options (Profile Formulas and Fast Formulas)?
1. I creating the Neural fit by using the "Save Formulas" option (so I can get each node's formula).
2. This creates five formula columns (4 for the nodes, 1 for the final prediction).
3. I create correlating columns in the smaller dataset manually for each of the five formula columns. 4. I go into the larger dataset, open each of the Neural formula column's "Properties" and then select "Formula" and copy the formula over into each of the five corresponding columns I made in the smaller dataset. 3. I also copy the column general properties over by just right clicking the column and copying the column properties.
