robot
Insert contents of Parse expression rather than variable name into New Script
I am looking to extend @Craige_Hales excellent answer from Insert contents of variable/expression rather than variable name into New Script by combining script, but have not worked out the syntax.  Any ideas to get this to work?
I am using JMP 18.1.2
dt = New Table( "My Table" );
e1 = Expr(
	Print( "Run some code." )
e2 = Expr(
	Print( "Run some other code." )
e3 = Expr(
	Parse( Eval Insert( "\[
	^e1^;
	^e2^;
// These work.
Eval( Eval Expr( dt << New Script( "Test 1", Expr( Name Expr( e1 ) ) ) ) );
Eval( Eval Expr( dt << New Script( "Test 2", Expr( Name Expr( e2 ) ) ) ) );
// This does not work.
Eval( Eval Expr( dt << New Script( "Test 3", Expr( Name Expr( e3 ) ) ) ) );
Re: Insert contents of Parse expression rather than variable name into New Script
Print your e3 to see what it contains
Name Expr(e3) = Parse(Eval Insert("
	^e1^;
	^e2^;
This possibly does what you are looking for
dt = New Table("My Table");
e1 = Expr(Print("Run some code."));
e2 = Expr(
	Print("Run some other code.")
e3 = Parse(Eval Insert("\[
	^Name Expr(e1)^;
	^Name Expr(e2)^;
Eval(Eval Expr(dt << New Script("Test 3", Expr(Name Expr(e3)))));
I would generally avoid using Parse as it is a nightmare to debug
e2 = Expr(
e3 = EvalExpr(
	Expr(Name Expr(e1));
	Expr(Name Expr(e2));
	^e1^;
	^e2^;
e2 = Expr(
	^Name Expr(e1)^;
	^Name Expr(e2)^;
e2 = Expr(
e3 = EvalExpr(
robot
Excellent!
