giarussi
Application compatibility between releases 15 and 16
We have developed an Application in JMP 15 and it worked fine in other JMP 15 clients.
Months later we have just opened the Application (developed in JMP 15) in JMP 16, no changes have been made, then saved.
After this operation the application does not work any more in JMP 15 and the error is:
Unknown Color
unknown or not implemented in access or evaluation of 'UI Only' , UI Only( 0 ) /*###*/
Is there a work around to get the application working back in JMP 15?
thanks a lot
none
mikedriscoll
Re: Application compatibility between releases 15 and 16
I've never really used the application feature, but this might work.
Save a backup of your existing application file.
Open a copy / of the app file in a text editor and do a search for "ui". in my dummy app file i found two instances of "ui only(0)". Delete them and save the file in the editor.
If it works, i'd definitely suggest making a backup of it!  In my testing I found that when i deleted the lines, then reopened in JMP 16, it added those two lines again after opening / saving in JMP 16.  I don't have JMP15 installed on my new PC so i can't test that.
giarussi
thanks for the reply.
I have deleted all instances of "ui only(0)", saved and opened in JMP 15 but it crashes and the error appear more severe than the previous one, also no log messages are emitted.  Thanks for try.
none
Jeff_Perkinson
This is an application created using Application Builder? If not, please give us some more detail about the application.
If so, I'm not sure what's going on here. It's probably best to reach out to Technical Support, support@jmp.com, and let them help you investigate what's happening.
-Jeff
