ComplexNerd
Application Builder - Graph Builder Interface
I am new to jmp platform and scripting. In application builder interface, when a button is clicked i want to open the graph builder inferface with loaded data columns (same interface as in Analysis - Graph Builder) where user can create graph needed then import the graph into the app screen.
i want to incroprate all the intractive features of Graph Builder interface (from selecting graph type , multiple x y columns etc) in application builder.
With my current understanding :
Is there a source code for Graph builder interface in jmp which can be used directly in appplication developer (or) is it possible to code the interface in the application developer
Note : Since i am new to jmp scripting .. developing custom graph builder interface is a heavy task. But i can build similar thing in python interface. Is it possible to embed python graph builder interface in Application devleoper of JMP ( If yes please specify the python interface packages supported)
Thanks in advance
Re: Application Builder - Graph Builder Interface
Hi @ComplexNerd - welcome to JMP!
I have attached a small JMP Application that demonstrates two ways to launch platforms in response to a button click.  In JSL, a platform launch typically looks like this:
dt << Graph Builder(<options>);
The default behavior when launching platforms is for the new report to create a new window, but you can also embed the platform into an existing window, which I demonstrate in the sample application.  This App was built with the Big Class sample data, but it will run on any JMP data table.
I hope that helps!
-Dan
I hope that helps!
-Dan
ComplexNerd
Thanks for very quick reply. I dint know it was this straightforward. Sorry if it seemed silliy. Thanks a bunch
ComplexNerd
also is it possible to export this tabbed report as interactive html. i tried using
ReportPanel<<Save Interactive HTML("$DESKTOP/example.html");
Current Report()<<Save Interactive HTML("$DESKTOP/example.html");
but both didnt reatin the tabbing. 1st one instaed created a stacked plots of generated reports. But local data filters are not interactive in either case. Kindly help Thanks in advance
