BHarris
Any command-line way to export .jmp files to TSV on macOS?
I’m wondering if there’s any command-line utility on macOS that can convert a .jmp file to something like TSV or CSV — for example:
jmp2tsv myFile.jmp  -->  myFile.tsv
I realize JMP is primarily a GUI tool, but I’ve seen other applications ship small CLI utilities (sometimes tucked inside the .app bundle) that leverage their native file readers for simple conversions like this.
Does anything like that exist for JMP today, either officially or unofficially? I poked around inside the JMP 19.app package but didn’t see anything obvious.
If not, I’d be curious whether anyone has found a lightweight workaround that avoids opening JMP interactively.
BHarris
Re: Any command-line way to export .jmp files to TSV on macOS?
Nice!  I asked ChatGPT to build a python version of that script and it did.  Of course it crashed on first-run, but with a couple back-and-forths with it, I now have a working python version.
Since I invested so little personally, I don't mind sharing here.  Note, I have only done rudimentary testing, so I'm not sure how it will handle various edge cases -- YMMV.  Feel free to use/update/share.
#! /usr/bin/env python3
from __future__ import annotations
import gzip
import io
import math
import re
import struct
from dataclasses import dataclass
from datetime import datetime, timedelta
from pathlib import Path
from typing import Any, BinaryIO, Sequence
import numpy as np
import pandas as pd
MAGIC_JMP = bytes([
	0xFF, 0xFF, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00,
	0x04, 0x00, 0x00, 0x00, 0x01, 0x00, 0x01, 0x00,
	0x02, 0x00,
GZIP_SECTION_START = bytes([0xEF, 0xBE, 0xFE, 0xCA])
JMP_STARTDATE = datetime(1904, 1, 1)
ROWSTATE_MARKERS = [
	'•', '+', 'X', '□', '◊', '△', 'Y', 'Z', '◯', '▭', '▯', '*', '⚫', '▬', '▮', '■',
ROWSTATE_COLORS = [
	'#000000', '#555555', '#787878', '#C0C0C0', '#FFFFFF', '#A00922', '#C91629', '#F03246',
	'#FF5C76', '#FF98A6', '#904700', '#BC5B03', '#E57406', '#FF9138', '#FFB17D', '#706F00',
	'#AFA502', '#DAD109', '#F0E521', '#FFF977', '#516A00', '#729400', '#90BF04', '#A2DC06',
	'#C1FF3D', '#00670C', '#11981B', '#21BC2D', '#23E72E', '#6AFF6B', '#007254', '#019970',
	'#04C791', '#06E3AA', '#0FFFBC', '#006D71', '#01989C', '#0CBCBC', '#06E2E3', '#67FFF7',
	'#00638F', '#0380B4', '#05A1D2', '#08C5F7', '#75E4FF', '#034AB0', '#0557D6', '#2867FD',
	'#4E9CFF', '#7E89FF', '#6A02A7', '#8C05CF', '#AB08FC', '#C170FF', '#D29AFF', '#930195',
	'#B803B9', '#DC06E1', '#FA50FF', '#FD96FF', '#9D0170', '#C5048D', '#E906A4', '#FF49BC',
	'#FF8CCD',
DATE_CODES = {
	(0x67, 0x65), (0x6F, 0x65), (0x72, 0x65), (0x72, 0x6F), (0x72, 0x7F),
	(0x72, 0x80), (0x7F, 0x72), (0x88, 0x65), (0x88, 0x7A),
DATE_CODES_SAME = {0x65, 0x66, 0x67, 0x6E, 0x6F, 0x70, 0x71, 0x72, 0x75, 0x76, 0x7A, 0x7F, 0x88, 0x8B}
DATETIME_DT5 = {0x69, 0x6A, 0x73, 0x74, 0x77, 0x78, 0x7E, 0x81}
DATETIME_DT4 = {0x69, 0x6A, 0x6C, 0x6D, 0x73, 0x74, 0x77, 0x78, 0x79, 0x7B, 0x7C, 0x7D, 0x7E, 0x80, 0x81, 0x82, 0x86, 0x87, 0x89, 0x8A}
DATETIME_CODES = {(0x77, 0x80), (0x77, 0x7F), (0x89, 0x65)}
DURATION_CODES = {(0x84, 0x79)}
DURATION_SAME = {0x0C, 0x6B, 0x6C, 0x6D, 0x83, 0x84, 0x85}
NUMERIC_SAME = {0x00, 0x03, 0x42, 0x43, 0x44, 0x59, 0x60, 0x63}
@dataclass
class Column:
	names: list[str]
	widths: list[int]
	offsets: list[int]
@dataclass
class Info:
	version: str
	buildstring: str
	savetime: datetime | None
	nrows: int
	ncols: int
	column: Column
@dataclass
class RowState:
	marker: str
	color: tuple[int, int, int]
class JMPReaderError(Exception):
	pass
class _MarkedReader:
	def __init__(self, fh: BinaryIO):
		self.fh = fh
		self._mark: int | None = None
	def tell(self) -> int:
		return self.fh.tell()
	def seek(self, offset: int, whence: int = io.SEEK_SET) -> int:
		return self.fh.seek(offset, whence)
	def read(self, n: int = -1) -> bytes:
		return self.fh.read(n)
	def skip(self, n: int) -> None:
		self.fh.seek(n, io.SEEK_CUR)
	def peek1(self) -> int:
		pos = self.tell()
		b = self.read(1)
		self.seek(pos)
		if not b:
			raise EOFError("Unexpected EOF")
		return b[0]
	def mark(self) -> None:
		self._mark = self.tell()
	def reset(self) -> None:
		if self._mark is None:
			raise JMPReaderError("No mark() has been set")
		self.seek(self._mark)
	def seek_end(self) -> int:
		return self.seek(0, io.SEEK_END)
# low-level helpers
def _read_exact(r: _MarkedReader, n: int) -> bytes:
	data = r.read(n)
	if len(data) != n:
		raise EOFError(f"Expected {n} bytes, got {len(data)}")
	return data
def _read_fmt(r: _MarkedReader, fmt: str):
	size = struct.calcsize(fmt)
	return struct.unpack(fmt, _read_exact(r, size))[0]
def _read_string(r: _MarkedReader, width: int) -> str:
	if width == 1:
		n = _read_fmt(r, '<b')
	elif width == 2:
		n = _read_fmt(r, '<h')
	elif width == 4:
		n = _read_fmt(r, '<i')
	else:
		raise ValueError(f"Invalid string width {width}")
	if n < 0:
		raise JMPReaderError(f"Negative string length {n}")
	return _read_exact(r, n).decode('utf-8', errors='replace')
def _read_array(r: _MarkedReader, dtype: np.dtype, count: int) -> np.ndarray:
	return np.frombuffer(_read_exact(r, np.dtype(dtype).itemsize * count), dtype=dtype, count=count).copy()
def _read_until(r: _MarkedReader, needle: bytes) -> bytes:
	out = bytearray()
	n = len(needle)
	while True:
		b = r.read(1)
		if not b:
			raise EOFError(f"Could not find byte sequence {needle!r}")
		out += b
		if out[-n:] == needle:
			return bytes(out)
def _to_datetime_scalar(value: float | None) -> datetime | None:
	if value is None or (isinstance(value, float) and math.isnan(value)):
		return None
	return JMP_STARTDATE + timedelta(seconds=float(value))
def _normalize_sentinel(values: np.ndarray) -> np.ndarray:
	if values.dtype == np.float64:
		if np.isnan(values).any():
			return np.array([None if np.isnan(x) else float(x) for x in values], dtype=object)
		return values.astype(object)
	info = np.iinfo(values.dtype)
	sentinel = info.min + 1
	if np.any(values == sentinel):
		return np.array([None if int(x) == sentinel else int(x) for x in values], dtype=object)
def _rstrip_null_bytes(data: bytes) -> bytes:
	return data.rstrip(b'\x00')
def _to_fixed_strings(buffer: bytes, nrows: int, width: int) -> list[str]:
	out: list[str] = []
	for i in range(nrows):
		chunk = buffer[i * width:(i + 1) * width]
		out.append(_rstrip_null_bytes(chunk).decode('utf-8', errors='replace'))
	return out
def _to_variable_strings(buffer: bytes, widths: Sequence[int]) -> list[str]:
	out: list[str] = []
	pos = 0
	buflen = len(buffer)
	for width in widths:
		width = int(width)
		if width < 0:
			raise JMPReaderError(f'Negative string width {width}')
		end = pos + width
		if end > buflen:
			# Clamp instead of reading past the payload. This avoids contamination
			# from adjacent bytes when one width table entry is slightly wrong.
			end = buflen
		text = buffer[pos:end].decode('utf-8', errors='replace')
		out.append(text)
		pos += width
	return out
def _find_names(names: Sequence[str], rules: Sequence[Any]) -> list[int]:
	out: list[int] = []
	for rule in rules:
		if isinstance(rule, int):
			out.append(rule)
		elif isinstance(rule, range):
			out.extend(list(rule))
		elif isinstance(rule, slice):
			start = 1 if rule.start is None else rule.start
			stop = len(names) if rule.stop is None else rule.stop
			step = 1 if rule.step is None else rule.step
			out.extend(list(range(start, stop + (1 if step > 0 else -1), step)))
		elif isinstance(rule, str):
			if rule.startswith('re:'):
				pat = re.compile(rule[3:])
				out.extend(i + 1 for i, name in enumerate(names) if pat.search(name))
			else:
				try:
					out.append(names.index(rule) + 1)
				except ValueError:
					pass
		elif isinstance(rule, re.Pattern):
			out.extend(i + 1 for i, name in enumerate(names) if rule.search(name))
	return out
def _filter_columns(names: Sequence[str], select: Sequence[Any] | None, drop: Sequence[Any] | None) -> list[int]:
	cols = set(range(1, len(names) + 1))
	if select is not None:
		cols &= set(_find_names(names, select))
	if drop is not None:
		cols -= set(_find_names(names, drop))
	return sorted(cols)
def _bitcat(a: int, b: int) -> int:
	return ((a & 0xFF) << 8) | (b & 0xFF)
def _hex_to_rgb(s: str) -> tuple[int, int, int]:
	s = s.lstrip('#')
	return (int(s[0:2], 16), int(s[2:4], 16), int(s[4:6], 16))
def _decode_numeric_block(a: bytes, width: int, nrows: int, kind: str) -> np.ndarray:
	dtype = {1: np.int8, 2: np.int16, 4: np.int32}.get(width, np.float64)
	data = np.frombuffer(a[-width * nrows:], dtype=dtype, count=nrows).copy()
	data = _normalize_sentinel(data)
	if kind == 'plain':
		return data
	if kind == 'date':
		return np.array([None if x is None else _to_datetime_scalar(float(x)).date() for x in data], dtype=object)
	if kind == 'datetime':
		return np.array([None if x is None else _to_datetime_scalar(float(x)) for x in data], dtype=object)
	if kind == 'time':
		def conv(x: Any):
			if x is None:
				return None
			dt = _to_datetime_scalar(float(x))
			return dt.time().replace(microsecond=0)
		return np.array([conv(x) for x in data], dtype=object)
	if kind == 'duration':
		return np.array([None if x is None else timedelta(seconds=float(x)) for x in data], dtype=object)
	raise ValueError(kind)
# metadata parsing
def check_magic(fh: BinaryIO) -> bool:
	fh.seek(0)
	return fh.read(len(MAGIC_JMP)) == MAGIC_JMP
def seek_to_column_data_offsets(r: _MarkedReader, ncols: int) -> tuple[int, int]:
	r.seek(0)
	r.skip(2)
	while True:
		_read_until(r, b'\xff\xff')
		while True:
			try:
				b = r.peek1()
			except EOFError as exc:
				raise JMPReaderError('Could not find column offset data') from exc
			if b != 0xFF:
				break
			r.skip(1)
		r.skip(10)
		n_visible = _read_fmt(r, '<I')
		n_hidden = _read_fmt(r, '<I')
		r.skip(8)
		if n_visible + n_hidden == ncols:
			return int(n_visible), int(n_hidden)
		r.skip(-18)
def _validate_column_info_candidate(r: _MarkedReader, candidate_pos: int, ncols: int) -> tuple[list[str], list[int]] | None:
	cur = r.tell()
	try:
		r.seek(candidate_pos)
		ncols2 = _read_fmt(r, '<i')
		if ncols2 != ncols:
			return None
		offsets = _read_array(r, np.int64, ncols).astype(np.int64).tolist()
		filesize = r.seek_end()
		if not offsets:
			return None
		if any(off < 0 or off >= filesize for off in offsets):
			return None
		if offsets != sorted(offsets):
			return None
		names: list[str] = []
		for off in offsets:
			r.seek(off)
			if n < 0 or n > 1024 or off + 2 + n > filesize:
				return None
			raw = _read_exact(r, n)
			s = raw.decode('utf-8', errors='replace')
			if not s:
				return None
			names.append(s)
		return names, offsets
	except Exception:
		return None
	finally:
		r.seek(cur)
def column_info(r: _MarkedReader, ncols: int) -> tuple[list[str], list[int]]:
	start = r.tell()
	while True:
		two = _read_exact(r, 2)
		if two in {b'\xfc\xff', b'\xfd\xff', b'\xfe\xff', b'\xff\xff'}:
			n = _read_fmt(r, '<q')
			if n < 0:
				raise JMPReaderError(f'Negative skip length while parsing column info: {n}')
			r.skip(n)
		else:
			r.skip(-2)
			break
	direct_pos = r.tell()
	out = _validate_column_info_candidate(r, direct_pos, ncols)
	if out is not None:
		return out
	# The Julia reader notes this area is hacky. Some JMP files appear to include
	# extra marker bytes before the actual Int32 ncols field. Fall back to a local
	# scan for a plausible column-info block.
	scan_origin = max(0, start - 16)
	scan_limit = min(r.seek_end(), direct_pos + 8192)
	r.seek(scan_origin)
	blob = _read_exact(r, scan_limit - scan_origin)
	needle = struct.pack('<i', ncols)
	for rel in range(0, max(0, len(blob) - 4) + 1):
		if blob[rel:rel+4] != needle:
			continue
		candidate_pos = scan_origin + rel
		out = _validate_column_info_candidate(r, candidate_pos, ncols)
		if out is not None:
			return out
	r.seek(direct_pos)
		f'Number of columns read from two locations do not match: {ncols} vs {ncols2}. '
		'Also failed to recover by scanning for a plausible column-info block.'
def metadata(fh: BinaryIO) -> Info:
	r = _MarkedReader(fh)
	r.seek(0)
	_read_until(r, bytes([0x07, 0x00, 0x08, 0x00, 0x00, 0x00]))
	r.seek(r.tell() - 38)
	nrows = int(_read_fmt(r, '<q'))
	ncols = int(_read_fmt(r, '<i'))
	_ = _read_array(r, np.int16, 5)
	_charset = _read_string(r, 4).rstrip('\x00')
	_ = _read_array(r, np.uint16, 3)
	savetime = _to_datetime_scalar(float(_read_fmt(r, '<d')))
	_ = _read_fmt(r, '<H')
	buildstring = _read_string(r, 4)
	m = re.search(r'Version (?P<version>.*)$', buildstring)
	if not m:
		raise JMPReaderError('Could not determine JMP version')
	version = m.group('version')
	n_visible, n_hidden = seek_to_column_data_offsets(r, ncols)
	_ = _read_array(r, np.uint32, n_visible)
	_ = _read_array(r, np.uint32, n_hidden)
	colwidths = _read_array(r, np.uint16, ncols).astype(np.uint16).tolist()
	_ = _read_array(r, np.uint32, 7)
	colnames, coloffsets = column_info(r, ncols)
	return Info(version, buildstring, savetime, nrows, ncols, Column(colnames, colwidths, coloffsets))
# column parsing
def _read_compressed_payload(r: _MarkedReader | None) -> bytes:
	_read_until(r, GZIP_SECTION_START)
	gziplen = _read_fmt(r, '<Q')
	gunziplen = _read_fmt(r, '<Q')
	raw = _read_exact(r, gziplen)
	try:
		return gzip.decompress(raw)
	except Exception as exc:
		raise JMPReaderError(f'Failed to gunzip compressed column ({gunziplen} bytes expected)') from exc
def _read_uncompressed_column_bytes(r: _MarkedReader, col_offset: int, next_col_offset: int | None) -> bytes:
	end = next_col_offset
	if end is None:
		cur = r.tell()
		end = r.seek_end()
		r.seek(cur)
	r.seek(col_offset)
	return _read_exact(r, end - r.tell())
def column_data(fh: BinaryIO, info: Info, i: int) -> Any:
	if not 1 <= i <= info.ncols:
		raise IndexError(f'requested column {i} is out of bounds')
	col_offset = info.column.offsets[i - 1]
	next_col_offset = info.column.offsets[i] if i < info.ncols else None
	r.seek(col_offset)
	_name = _read_string(r, 2)
	dt1, dt2, dt3, dt4, dt5, dt6 = struct.unpack('<6B', _read_exact(r, 6))
	r.mark()
	if dt1 in {0x09, 0x0A}:
		a = _read_compressed_payload(r)
	else:
		a = _read_uncompressed_column_bytes(r, col_offset, next_col_offset)
		r.reset()
	if dt1 in {0x01, 0x0A}:
		if (dt4 == dt5 and dt4 in NUMERIC_SAME) or dt5 in {0x5E, 0x63}:
			return _decode_numeric_block(a, dt6, info.nrows, 'plain')
		if dt4 == dt5 and dt4 in {0x5F, 0x54, 0x55, 0x56, 0x51, 0x52, 0x53}:
		if (dt4 == dt5 and dt4 in DATE_CODES_SAME) or (dt4, dt5) in DATE_CODES:
			return _decode_numeric_block(a, dt6, info.nrows, 'date')
		if ((dt5 in DATETIME_DT5 and dt4 in DATETIME_DT4) or
			(dt4 == dt5 and dt4 in {0x79, 0x7D}) or
			((dt4, dt5) in DATETIME_CODES)):
			return _decode_numeric_block(a, dt6, info.nrows, 'datetime')
		if dt4 == dt5 and dt4 == 0x82:
			return _decode_numeric_block(a, dt6, info.nrows, 'time')
		if (dt4 == dt5 and dt4 in DURATION_SAME) or ((dt4, dt5) in DURATION_CODES):
			return _decode_numeric_block(a, dt6, info.nrows, 'duration')
	if dt1 in {0xFF, 0xFE, 0xFC}:
		return _decode_numeric_block(a, dt5, info.nrows, 'plain')
	if dt1 == 0x09 and dt2 == 0x03:
		width = dt5
		out: list[RowState] = []
		for row in range(info.nrows):
			offset = width * row
			markeridx = _bitcat(a[offset + 6], a[offset + 5])
			if markeridx <= 0x001F:
				marker = ROWSTATE_MARKERS[markeridx]
			else:
				marker = chr(markeridx)
			if a[offset + 3] == 0xFF:
				rgb = (a[offset + 2], a[offset + 1], a[offset + 0])
			else:
				rgb = _hex_to_rgb(ROWSTATE_COLORS[a[offset + 0]])
			out.append(RowState(marker=marker, color=rgb))
		return out
	if dt1 == 0x03 and dt2 == 0x03:
		return np.frombuffer(a[-dt5 * info.nrows:], dtype=np.int64, count=info.nrows).copy()
	if dt1 in {0x02, 0x09} and dt2 in {0x01, 0x02}:
		# fixed-width character
		if ((dt3, dt4) == (0x00, 0x00) and dt5 > 0) or (0x01 <= dt3 <= 0x07 and dt4 == 0x00):
			width = dt5
			data = a[-info.nrows * width:]
			return _to_fixed_strings(data, info.nrows, width)
		# variable-width character
		if (dt3, dt4, dt5) == (0x00, 0x00, 0x00):
			if dt1 == 0x09:
				total_len = struct.unpack('<q', a[:8])[0]
				if total_len == len(a):
					bio = io.BytesIO(a)
					_reclen = struct.unpack('<q', bio.read(8))[0]
					_foo = bio.read(9)
					_foo2 = struct.unpack('<q', bio.read(8))[0]
					width_bytes = struct.unpack('<b', bio.read(1))[0]
					idx_dtype = {1: np.uint8, 2: np.uint16, 4: np.uint32}[width_bytes]
					idx = np.frombuffer(bio.read(info.nrows * np.dtype(idx_dtype).itemsize), dtype=idx_dtype, count=info.nrows)
					npools = int(idx.max()) if len(idx) else 0
					if width_bytes == 1:
						len_fmt = '<B'
					elif width_bytes == 2:
						len_fmt = '<H'
					elif width_bytes == 4:
						len_fmt = '<I'
					else:
						raise JMPReaderError(f'Unsupported pooled string pool width: {width_bytes}')
					pool: list[str] = []
					for _ in range(npools):
						n = struct.unpack(len_fmt, bio.read(struct.calcsize(len_fmt)))[0]
						text = bio.read(n).decode('utf-8', errors='replace')
						pool.append(text)
					return ["" if int(j) == 0 else pool[int(j) - 1] for j in idx]
				widthbytes = a[8]
				if widthbytes == 1:
					widths = np.frombuffer(a[13:13 + info.nrows], dtype=np.int8, count=info.nrows).astype(int)
					data = a[13 + info.nrows:]
				elif widthbytes == 2:
					widths = np.frombuffer(a[13:13 + 2 * info.nrows], dtype=np.int16, count=info.nrows).astype(int)
					data = a[13 + 2 * info.nrows:]
				else:
					raise JMPReaderError(f'Unknown widthbytes={widthbytes} in compressed char column {i}')
				return _to_variable_strings(data, widths)
			else:
				r.reset()
				r.skip(6)
				n1 = _read_fmt(r, '<q')
				r.skip(n1)
				r.skip(2)
				n2 = _read_fmt(r, '<I')
				r.skip(n2 + 8)
				widthbytes = _read_fmt(r, '<B')
				_maxwidth = _read_fmt(r, '<I')
				width_dtype = {1: np.int8, 2: np.int16, 4: np.int32}.get(widthbytes)
				if width_dtype is None:
					raise JMPReaderError(f'Unknown widthbytes={widthbytes} in uncompressed char column {i}')
				widths = _read_array(r, width_dtype, info.nrows).astype(int)
				if next_col_offset is None:
					cur = r.tell()
					colend = r.seek_end()
					r.seek(cur)
				else:
					colend = next_col_offset
				data_len = int(widths.sum())
				data_offset = colend - data_len
				r.seek(data_offset)
				data = _read_exact(r, data_len)
	return np.array([math.nan] * info.nrows)
# public API
def readjmp(path: str | Path, select: Sequence[Any] | None = None, drop: Sequence[Any] | None = None) -> pd.DataFrame:
	Read a JMP .jmp table into a pandas DataFrame.
	Parameters
	path:
		Path to the .jmp file.
	select / drop:
		Optional column filters. Elements may be 1-based integers, ranges,
		exact strings, compiled regex patterns, or strings of the form
		"re:<pattern>".
	path = Path(path)
	if not path.is_file():
		raise FileNotFoundError(path)
	with path.open('rb') as fh:
		if not check_magic(fh):
			raise JMPReaderError(f'{path} does not appear to be a valid .jmp file')
		info = metadata(fh)
	colinds = _filter_columns(info.column.names, select, drop)
	data: dict[str, Any] = {}
	for i in colinds:
			data[info.column.names[i - 1]] = column_data(fh, info, i)
	df = pd.DataFrame(data)
	df = df[[info.column.names[i - 1] for i in colinds]]
	return df
if __name__ == '__main__':
	import argparse
	# import json
	parser = argparse.ArgumentParser(description='Read a JMP .jmp file into TSV/JSON using a pure-Python reader.')
	parser.add_argument('jmp_file', help='Path to the JMP .jmp file')
	parser.add_argument('-o', '--output', help='Write TSV to this file. Defaults to stdout preview.')
	parser.add_argument('--json', action='store_true', help='Write JSON instead of TSV/plain-text output')
	parser.add_argument('--select', nargs='*', default=None, help='Columns to include (names or 1-based indices)')
	parser.add_argument('--drop', nargs='*', default=None, help='Columns to exclude (names or 1-based indices)')
	args = parser.parse_args()
	def coerce_rules(values: list[str] | None) -> list[Any] | None:
		if values is None:
			return None
		out: list[Any] = []
		for v in values:
			try:
				out.append(int(v))
			except ValueError:
				out.append(v)
		return out
	df = readjmp(args.jmp_file, select=coerce_rules(args.select), drop=coerce_rules(args.drop))
	if args.output:
		if args.json:
			Path(args.output).write_text(df.to_json(orient='records', default_handler=str, force_ascii=False, indent=2),encoding='utf-8')
		else:
			df.to_csv(args.output, sep='\t', index=False)
	else:
		if args.json:
			print(df.to_json(orient='records', default_handler=str, force_ascii=False, indent=2))
		else:
			with pd.option_context('display.max_columns', None, 'display.width', 200):
				print(df.to_string(index=False))
7 REPLIES 7
MathStatChem
To run a script on the command line you do something like this:
~> /Applications/JMP\ Pro\ 18.app/Contents/MacOS/JMP -nosplash -startup '"/path/to/your_script.jsl"'
the script may need the "auto-run" escape at the beginning of the script, and you could/shoud use the Quit() function at the end of the script.   Unsure, though, how to pass a file path or other arguments on the command line.
you could write a shell script, something like this:
#!/bin/bash
# jmp2csv.sh - Convert a JMP file to CSV
if [ -z "$1" ]; then
echo "Usage: jmp2csv.sh input.jmp [output.csv]"
exit 1
fi
INPUT="$(cd "$(dirname "$1")" && pwd)/$(basename "$1")"
OUTPUT="${2:-${INPUT%.jmp}.csv}"
# Make output path absolute if not already
case "$OUTPUT" in
*) OUTPUT="$(pwd)/$OUTPUT" ;;
esac
TMPJSL=$(mktemp /tmp/jmp2csv_XXXXXX.jsl)
cat > "$TMPJSL" << EOF
dt = Open("$INPUT", Invisible);
dt << Save As("$OUTPUT", "CSV");
dt << Close Window;
Quit();
EOF
open -a "JMP Pro 18" "$TMPJSL"
Make it executable with chmod +x jmp2csv.sh, then use it like:
./jmp2csv.sh /path/to/data.jmp
./jmp2csv.sh /path/to/data.jmp /path/to/output.csv
Of course, this only works on MacOS.  Not sure what the windows equivalent would be.
BHarris
Thanks -- this is really clever.  I appreciate you taking the time to lay it out so clearly.
That said, this approach feels pretty heavy for what I had in mind. Spinning up a full JMP instance just to convert a file is more than I'd likely do in practice, especially trying to fold something like this into a lightweight pipeline.
I was imagining something more along the lines of a small utility that leverages JMP's file readers without bringing up the full application — the kind of thing some tools quietly include inside their .app bundle for simple format conversions.  Totally understand that this may not exist today, but I figured it was worth asking in case I was missing something.
It feels like there could be a nice opportunity here for a simple, built-in utility if others would find it useful as well.
hogi
Level XIII
BHarris
import gzip
import io
import math
import re
import struct
import numpy as np
import pandas as pd
MAGIC_JMP = bytes([
	0x02, 0x00,
ROWSTATE_COLORS = [
	'#FF8CCD',
DATE_CODES = {
@dataclass
class Column:
	names: list[str]
	widths: list[int]
	offsets: list[int]
@dataclass
class Info:
	version: str
	buildstring: str
	nrows: int
	ncols: int
	column: Column
@dataclass
class RowState:
	marker: str
	pass
		self.fh = fh
		pos = self.tell()
		b = self.read(1)
		self.seek(pos)
		if not b:
		return b[0]
# low-level helpers
	data = r.read(n)
	if len(data) != n:
	return data
	if width == 1:
	elif width == 2:
	elif width == 4:
	else:
	if n < 0:
	out = bytearray()
	n = len(needle)
	while True:
		b = r.read(1)
		if not b:
		out += b
			return bytes(out)
		return None
	out: list[str] = []
	return out
	out: list[str] = []
	pos = 0
		width = int(width)
		if width < 0:
		end = pos + width
		if end > buflen:
			end = buflen
		out.append(text)
		pos += width
	return out
	out: list[int] = []
	for rule in rules:
			out.append(rule)
			else:
				try:
				except ValueError:
					pass
	return out
	return sorted(cols)
	s = s.lstrip('#')
	if kind == 'plain':
		return data
	if kind == 'date':
	if kind == 'time':
		def conv(x: Any):
			if x is None:
				return None
# metadata parsing
	fh.seek(0)
	r.seek(0)
	r.skip(2)
	while True:
		while True:
			try:
				b = r.peek1()
			if b != 0xFF:
				break
			r.skip(1)
		r.skip(10)
		r.skip(8)
		r.skip(-18)
	cur = r.tell()
	try:
		if ncols2 != ncols:
			return None
		if not offsets:
			return None
			return None
			return None
		for off in offsets:
			r.seek(off)
				return None
			if not s:
				return None
			names.append(s)
	except Exception:
		return None
	finally:
		r.seek(cur)
	start = r.tell()
	while True:
			if n < 0:
			r.skip(n)
		else:
			r.skip(-2)
			break
	if out is not None:
		return out
	r.seek(scan_origin)
			continue
		if out is not None:
			return out
	r.seek(direct_pos)
	r.seek(0)
	if not m:
# column parsing
	try:
	if end is None:
		cur = r.tell()
		end = r.seek_end()
		r.seek(cur)
	r.seek(col_offset)
	r.seek(col_offset)
	r.mark()
	else:
		r.reset()
		width = dt5
			else:
			else:
		return out
			width = dt5
			if dt1 == 0x09:
					bio = io.BytesIO(a)
					_foo = bio.read(9)
						len_fmt = '<B'
						len_fmt = '<H'
						len_fmt = '<I'
					else:
						pool.append(text)
				widthbytes = a[8]
				if widthbytes == 1:
				else:
			else:
				r.reset()
				r.skip(6)
				r.skip(n1)
				r.skip(2)
				r.skip(n2 + 8)
					cur = r.tell()
					r.seek(cur)
				else:
				r.seek(data_offset)
# public API
	Parameters
	path:
	select / drop:
		"re:<pattern>".
	path = Path(path)
		info = metadata(fh)
	for i in colinds:
	return df
	import argparse
	# import json
		if values is None:
			return None
		out: list[Any] = []
		for v in values:
			try:
				out.append(int(v))
			except ValueError:
				out.append(v)
		return out
	if args.output:
		if args.json:
		else:
	else:
		if args.json:
		else:
Impressive.  The Julia code author or somebody spent a fair amount of time in a hex editor.  ( Though now with AI, it may be possible using sufficient prompt engineering to 'crack' any unencrypted file format. Treating known data input as the 'plaintext' and the resulting output file (.jmp) as 'ciphertext'. Passing enough known data through and seeing what happens... either path is pretty tedious. )
This looks like it's likely to work for basic data tables.  You won't get an evaluation of columns that contain formulas, images, ...   Also, I'm pretty sure it won't handle advance data table features such as linked tables where columns come from columns in other tables. Additionally, fairly old data tables have different header versions and if old enough, BigEndian vs LittleEndian format.
Just make sure you adequately validate your output before trusting in critical processes.  The beauty and the beast of open source code.
I tried it on the Iris.jmp => Iris.json, it seems pretty slow for the size of the data table 0.88s.  Have you compared with actual launch time of JMP from command line? Are you certain you can't just export from within JMP?  such as
import jmp
import pandas as pd
dt = jmp.current()
df = pd.api.interchange.from_dataframe(dt)
df.to_json('out.json')
BHarris
Writing a TSV out from JMP itself is pretty trivial. After I asked the question, I realized there are straightforward ways to solve my original problem that don’t involve the command line at all.
That said, when I mentioned the idea to a coworker, he immediately said, “This is exactly what (John Doe, who works on another team) needs — he doesn’t have a JMP license, but this would let him pull data out of our files when we’re not around.” I thought that was a surprisingly compelling use case.
And your point about caution is well taken. The utility worked flawlessly on Big Class, but when I tried it on another file, I hit a strange edge case: out of ~300 email addresses, one of them was transformed from “[email protected]” to “[email protected]” in the output. I can’t quite wrap my head around what kind of parsing issue would cause that in exactly one cell and nowhere else.
Definitely a good reminder to check outputs when using tools like this.
hogi
Level XIII
Indeed, then the JMP file format can reasonably be assumed to be publicly accessible.
Given that reality, an official, supported export path - tied to a JMP license - could actually pay off.
Making files hard to read is not a sustainable strategy - not against AI!
JMP’s real competitive advantage is - and always has been - its outstanding user experience.
One could even turn this into a positive lever: the barrier created by a proprietary format and the lack of a viewer may discourage some companies from using JMP. Lowering this barrier could encourage adoption by organizations that were previously hesitant - ultimately bringing more users into the JMP ecosystem.
Given that reality - an official, supported export path - tied to an existing JMP license - could it pay off?
