G_M
G_M
Any Advice: Fill Color not working in Graph Box?
Good morning,
for some reason the rectangles in this Graph Box are not filling with specified color.  Perhaps it is something simple that I am missing:
new Window("Test",
H List Box(
g0 = Graph Box(
			Frame Size(50, 500),
			Y Scale(-1, 6),
			X Scale(0, 6),
			Fill Color("Green");
			Rect(0, 1.1, 6, 0);
			Fill Color("Yellow");
			Rect(0, 1.6, 6, 1.1);
			Fill Color("Orange");
			Rect(0, 1.8, 6, 1.6);
			Fill Color("Red");
			Rect(0, 5.9, 6, 1.8);
g1 = Graph Box(
			Y Scale(-1, 6),
			X Scale(0, 6),
			Rect(0, 1.1, 6, 0);
			Fill Color("Red");
g2 = Graph Box(
			Y Scale(-1, 6),
			X Scale(0, 6),
			Rect(0, 1.1, 6, 0);
			Fill Color("Red");
g3 = Graph Box(
			Y Scale(-1, 6),
			X Scale(0, 6),
			Rect(0, 1.1, 6, 0);
			Fill Color("Red");
g0[Axis Box(1)]<< Delete;
g1[Axis Box(1)]<< Delete;
g2[Axis Box(1)]<< Delete;
g3[Axis Box(1)]<< Delete;
Thanks in Advance!
MG
Re: Any Advice: Fill Color not working in Graph Box?
You need to add a 5th element to the Rect() function. The 5th element specifies if the rectangle is to be filled (1) or not filled (0). See the Scripting Index for more info.
rect( 11,15,15,11,1)
G_M
G_M
I got it, I need to add the Boolean for Fill..
