GroupSquareWolf
Analysis with user selected columns - Scripting
Trying to write a script to perform curve fitting based on user selected columns.
In the example below, the goal is to fit linear with X and Y based on :Group and/or  :Type. User can select either or both columns and then run the script.
This is what I've got
dt1 = current datatable();
sc = dt1 << get selected Columns;
scn= column (sc) << get name;
show (sc);
show (scn); obj = dt1 <<Fit Curve( Y( :Y ), X( :X ), Fit linear, By( scn )
// By (sn) );
In Log
show (sc); spits out:      sc = {:Group, :Type};
show (scn); spits out;      scn = "Group";
In Fit curves, neither "By (scn)" nor "By(sc)" can achieve the function of "By (:Group, :Type) or By(:Group).
What is the correct code to make this work?
Thanks!
Re: Analysis with user selected columns - Scripting
One option would be to add Eval() around scn:
dt1 = Current Data Table();
scn = Column(sc) << get name;
Show(sc);
Show(scn);
obj = dt1 << Fit Curve(
	Y(:Y),
	X(:X),
	Fit linear,
	By(Eval(scn))//  By (sn)
pmroz
This works too:
dt1 = New Table( "Test", Add Rows( 6 ),
	New Column( "X", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [1, 2, 3, 1, 2, 4] ) ),
	New Column( "Y", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [3, 2, 5, 6, 4, 3] ) ),
	New Column( "XY Group", Character, "Nominal", Set Selected,
		Set Values( {"A", "A", "A", "B", "B", "B"} ) )
scn = Column(sc[1]) << get name;	// sc is a list - get the first highlighted column
Show(sc);
Show(scn);
	Y(:Y),
	X(:X),
	Fit linear,
	by (column(dt1, scn))
Show(sc);
Show(scn);
	Y(:Y),
	X(:X),
	Fit linear,
pmroz
This works too:
Show(sc);
Show(scn);
	Y(:Y),
	X(:X),
	Fit linear,
