YGerchman
Analysis By/Page Ordering
Hi all,
I have a Partition analysis with "by" column. that means that I have a couple of "pages" (=plots).
obj1=Partition(
Y( col1 ),
X( col2 ),
Show Split Prob( 1 ),
Informative Missing( 1 ),
By( col3));
part1=obj1<<report;
In addition, I would be glad if I could arrange them in an order (based on the second level probability).
so- I built 2nd table with order number of each table. it looks like this:
part1[x]    Probability     order
       1             0.23            2
       2             0.21            1
       3             0.52            4
       4             0.32            3
how could I show the plots in the order I want? (with or without the 2nd table)
note: If I will send to report or journal - the plots no longer will be interactive which is not good for the application at all.
thank you all,
Yoav.
YGerchman
Re: Analysis By/Page Ordering
the bottom-left one. but in my data - i have only 2 levels (0 or 1).
in any case- i've figure it out by getting partition script and append in into new window.
nw=new window();
for(i,i<nrows(table),i++,
a=obj1[row i from order column ]<<get script;
nw<<append(a));
thanks in any case!
ih
Super User (Alumni) ih
I don't know of a way to do this interactively except to create a dashboard (maybe someone else does?), but you could make a fairly simple script to order them any way you like.  Add a local data filter to your platform and performing the analysis for a single level of your By element, and then copy/paste the script into a New Window script of your own:
Names default to here(1);
//open sample data
dt = Open("$Sample_data/big class.jmp");
//New window and V list box will create a window with each analysis below the previous one
win = New Window("Analysis",
	V List Box(
		//copy this script from the platform you used after adding a local data filter
		Bivariate(
			Y( :height ),
			X( :weight ),
			Local Data Filter(
				Close Outline( 1 ),
				Add Filter(
					columns( :age ),
					Where( :age == 14 ),
					Display( :age, N Items( 6 ) )
		//then add the comma (previous line), and paste it again, changing the data filter
		Bivariate(
			Y( :height ),
			X( :weight ),
			Local Data Filter(
				Close Outline( 1 ),
				Add Filter(
					columns( :age ),
					Where( :age == 13 ),
		Bivariate(
			Y( :height ),
			X( :weight ),
			Local Data Filter(
				Close Outline( 1 ),
				Add Filter(
					columns( :age ),
					Where( :age == 15 ),
//Now, if you want, you can hide all of the data filters:
(win << XPath("//OutlineBox[@helpKey='Data Filter']")) << Visibility("Hidden")
 I did just submit a wish list request for one way to make this easier:Respect value ordering in 'By' variable
Can you further specify what you mean by "(based on the second level probability)"?  Below is a simple run
//open sample data
dt = Open("$Sample_data/semiconductor capability.jmp");
obj1=Partition(
Y( :wafer ),
X( :pnp1 ),
Informative Missing( 1 ))
and here is the output from the following JSL after having performed 1 split on the data.
Which of the tables are you referring to when you ask for the "second level probability"?
YGerchman
nw=new window();
nw<<append(a));
thanks in any case!
