aidanweb
Adding outlines horizontally in journal
I'm looking to make a journal with "Smaller outlines" within "Bigger outlines". I don't want the top outline to expand vertically, but rather horizontally.
Edit: I see from an example journal (that looks like what I want) that the "Smaller Outlines" boxes should be List boxes with button boxes underneath... but I don't see an option to add either of these?
Re: Adding outlines horizontally in journal
As I'm not 100% sure what you want (don't know which example you are looking at), would the outline layout look something like this?
To get OutlineBoxes side by side in Journal this should be the location where you want to drop them (blue part)
David_Burnham
Once you have added content (e.g. by right-click) you can use the selection tool to move it around.
-Dave
aidanweb
Yes, that's exactly what I'm trying to do, thank you... but the only way I see to add an outline box is by right clicking on empty space and clicking "Add Outline Item." Are you dragging & dropping from somewhere? Plus, there seems to be only one big box where I can add items to.
David_Burnham
-Dave
