Adding multiple horizonal reference lines based on columns
I'm having trouble adding a horizontal reference line in my plot based on a column parameter. The code is attached below. I need the reference line to be a horizontal line not a vertical line:
Names Default to Here( 1 );
quantile_plot = Graph Builder(
	Size( 528, 631 ),
	Variables( X( :Dataset ), Y( :y ), Color( :SAMPLEID ) ),
	Elements( Points( X, Y, Legend( 4 ), Jitter( "Random Uniform" ) ) ),
	Local Data Filter(
		Add Filter(
			columns( :Gender, :Ethnicity, :Age, :Congener ),
			Where( :Gender == "1" ),
			Where( :Ethnicity == "3" ),
			Where( :Age == "4" ),
			Where( :Congener == "LBC028" ),
			Display( :Ethnicity, N Items( 5 ) ),
			Display( :Age, N Items( 4 ) ),
			Display( :Congener, N Items( 15 ), Find( Set Text( "" ) ) )
		Dispatch(
			"Dataset",
			ScaleBox,
			{Add Ref Line( -0.5, "Solid", "Red", "", 2 )}
		Dispatch(
			"y",
			ScaleBox,
			{Scale( "Log" ), Format( "Best", 6 ), Min( 0.261333735635329 ),
			Max( 20 ), Inc( 1 ), Minor Ticks( 1 )}
report(quantile_plot)[axisbox(2)] << Add Ref Line( threshold, "solid", black, "", 2 );
report(quantile_plot)[axisbox(2)]<<  min(threshold);
M. Dereviankin
Re: Adding multiple horizonal reference lines based on columns
Does the reference line appear if you translate or scale the Y axis to decrease the minimum value shown?  Since your script sets the min to the same value as the reference line, I would be concerned that numerical issues may cause the reference line to be clipped from view.
The line needs to be horizontal based on the value that is listed for, 'threshold'. I want these so I can automatically create a data filter and see how this line changes.
M. Dereviankin
