It's possible to use Graph Builder to show error bars without stacking the data. I.e. you have 3 separate columns: center point, upper limit and lower limit. Using the data above, you drag the X variable (age) to the X axis. Then highlight upper and lower and drag them to the Y axis. Right click in the center of the graph, click Points > Change to > Bar. Then right click in the graph, click Bar > Bar Style > Interval. Now drag the column Mean(height) just to the right of the Y axis. Next add connecting lines and remove the connecting lines for upper and lower.
Here's a JSL script that does it, along with some formatting:
// Make an example table
dt = Open( "$ENGLISH_SAMPLE_DATA/Big Class.jmp" );
dtsum = dt << Summary( Group( :age ), Mean( :height ), Std Err( :height ) );
// Add columns with Mean ± SE
dtsum << New Column( "lower", numeric,
values(
(:Name( "Mean(height)" ) << get as matrix) –
(:Name( "Std Err(height)" ) << get as matrix)
dtsum << New Column( "upper",
numeric,
values(
(:Name( "Mean(height)" ) << get as matrix) +
Graph Builder(
Variables(
X( :age ),
Y( :lower ),
Y( :upper, Position( 1 ) ),
Y( :Name( "Mean(height)" ), Position( 1 ) )
Elements(
Bar(
X,
Y( 1 ),
Y( 2 ),
Y( 3 ),
Legend( 2 ),
Bar Style( "Interval" ),
Summary Statistic( "Mean" )
Line( X, Y( 3 ), Legend( 4 ), Row order( 0 ), Summary Statistic( "Mean" ) )
Dispatch(
"400",
ScaleBox,
{Legend Model(
2,
Properties( 0, {Line Color( 0 )} ),
Properties( 1, {Line Color( 0 ), Marker( "FilledCircle" )} )
Dispatch( {}, "Graph Builder", FrameBox, {Marker Size( 3 )} )
