ben
ben
how do I add a reference lines to each control chart
In my script I am trying to add a reference line to each control chart. "Graph_line" is a list of values that I want to use as the reference lines. There are 63 items in Graph_lines which corresponds to the 63 different UNIT_MODELs that I am charting. I tried to use a for loop and I realize that this is somewhat primitive but my overall understanding of jmp right now is still low. Pleas help! Thanks
Control Chart(
	Group Size( 1 ),
	KSigma( 3 ),
	Chart Col( :Name( "Sum(BIN_COUNT, 1)" ), Individual Measurement ),
	by( :UNIT_MODEL),
	For(i = 1, i <= n items(Graph_line), i++,
	ref = Graph_line[i];
		Dispatch(
			{"Individual Measurement of Sum(BIN_COUNT, 1)"},
			"2",
			ScaleBox,
			{Add Ref Line( ref, "Solid", "Dark Blue", "", 2 )}
Re: how do I add a reference lines to each control chart
Apparently you and @bharathu
     How to add a reference line........
have the same homework assignment:-)
@ian_jmp gave a very good response to the question
