steveylin
Adding a search field to custom launch window
I have code here to create a custom launch window, as seen in the first image.  Is there a way to add a filter similar to what we normally see when we select analyze from menu?
clearCols = Expr( // Expression to clear all current settings
    selTests << Remove All;
recallCols = Expr(
    ::testsRecall = selTests << Get Items;
/* Custom Launch Window */
selTestsWindow = New Window( "Test Selection for dashboard", // GUI to select test to analyze
    <<Modal,
    <<return result,
    Border Box( Left( 3 ), top( 2 ),
        V List Box(
            H List Box(
                V List Box(
                    Panel Box( "Select Columns",
                        colListData =
                        Col List Box( all, <<set data type( "Numeric" ) )
                V List Box(
                    Panel Box( "Tests",
                        Lineup Box( N Col( 2 ), Spacing( 3 ),
                            Button Box( "Y, Response",
                                selTests <<
                                Append( colListData << Get Selected )
                            selTests =
                            Col List Box( MinItems( 1 ), "Numeric" ),
                Panel Box( "Action",
                    Lineup Box( N Col( 1 ),
                        okButton = Button Box( "OK",
                            recallCols;
                            test_list = selTests << Get Items;
                        Button Box( "Cancel" ),
                        Text Box( " " ),
                        Button Box( "Remove",
                            selTests << Remove Selected;
                        Button Box( "Recall",
                            clearCols;
/* Restore any previous settings from the global variables */
                            Try(
                                selTests << Append( ::testsRecall );
                        Button Box( "Reset", clearCols ),
recallCols = Expr(
JMP 16.1 MacOS
Re: Adding a search field to custom launch window
The box with the Find / Search functionality is the Filter Col Selector.  Because it is a composite box it can be a little more challenging to script - you will find discussions on the Community that may help for common use cases, such as this one that describes how you can show the filter field by default.
steveylin
Thanks Dan.  I got this code to work:
                 colListData = Filter Col Selector(dt),
                 colListData[IfBox(1)] << Set(1),
                 //colListData = Col List Box(all,<<set data type("Numeric"))
