statcon
Adding Points to a graphbox
i created an interaktive graph. Now i need to add points (or more general: geometric shapes) to the graphbox.
This should be done on a mousklick using MouseTrap().
I thought of soemthing like that:
// Ad a marker to the graph at the position where the mouse was pressed
::click = function({x,y},
  ::g << Marker(MarkerState(3), x, y);
  ::g << Circle(x, y, PixelRadius(10));
::w = New Window("Test",
  // Some other components (Textboxes...)
  ::g = Graph Box(
                    FrameSize( 300, 300 ),
                    Mousetrap( ::click( x, y ), {} )
But sadly this does not work. Is there a way to do something like that?
Thanks for any hints!
David_Burnham
A couple of points:
- coordinates are typically expressed in a list or matrix format
- the graphical functions operate within a graphics script
The following should work:
               pos = {};
               InsertInto(pos,x);
               InsertInto(pos,y);
       ::g[FrameBox(1)] << Add Graphics Script(
                        Marker(Marker State(3), pos) ;
                         Circle(pos, PixelRadius(10));
-Dave
-Dave
David_Burnham
A couple of points:
               pos = {};
               InsertInto(pos,x);
               InsertInto(pos,y);
-Dave
-Dave
statcon
Thanks it works exactly as i need it!
