Jackie_
Add reference line from the reference table
Hi, @txnelson
I am trying to create a variability plot graph and add a reference lines with different values for each of the individual charts. Currently I can plot the reference line but the problem is if the reference table doesn't contain all the test columns from the data table, the script won't work.
Here's what I tried and it works if the reference table has all the tests from the data table:
Clear Globals();
dt = Open("Data table.jmp"); // Open data table
// Loop to get column name Currents and Voltages
colist = {};
Col_List = dt << Get Column Names( "String" );
	For( q = 1, q <= N Items( Col_List ), q++,
		If( Contains( Col_List[q], "Current" ) | Contains( Col_List[q], "Voltage" ),
			Column( Col_List[q] ) << Set Selected( 1 );
			Insert Into( colist, Col_List[q] );
	// Var Chart
	vc= dt << Variability Chart(
								Y( (Eval( colist )) ),
								X( :Wafer ID ),
								Analysis Type( "Choose best analysis (EMS REML Bayesian)" ),
								Show Range Bars( 0 ),
								Std Dev Chart( 0 ),
								Points Jittered( 1 )
// Reference data table dt1 = Open ("Reference table.jmp"); xb = Column(dt1, "Reference") << getValues; // Loop to add reference line to the variability chart For( i = 1, i <= N Items( vc ), i++, Report( vc[i] )[Framebox( 1 )] << DispatchSeg( CustomStreamSeg( 3 ), {Line Width( 2 )} ); Report( vc[i] )[AxisBox( 1 )] << {Add Ref Line( xb[i], "Solid", "Green", "RTS", 2 )}; );
3 ACCEPTED SOLUTIONS
Re: Add reference line from the reference table
You could loop over colist and check if dt1 has that specific value with if statement and if it does then add reference line based on value found from dt1. Here is one option using Associative Array (you might have to add scaling to Y-axis for the variability charts, as reference lines can be hidden depending on their value).
// dt = Open("Data table.jmp"); // Open data table
// dt1 = Open("Reference table.jmp");
colist = {};
Col_List = dt << Get Column Names("String");
For(q = 1, q <= N Items(Col_List), q++,
	If(Contains(Col_List[q], "Current") | Contains(Col_List[q], "Voltage"),
		Column(Col_List[q]) << Set Selected(1);
		Insert Into(colist, Col_List[q]);
	// Var Chart
vc = dt << Variability Chart(
	Y((Eval(colist))),
	X(:Wafer ID),
	Analysis Type("Choose best analysis (EMS REML Bayesian)"),
	Show Range Bars(0),
	Std Dev Chart(0),
	Points Jittered(1)
);// Reference data table
aa_refs = Associative Array(dt1:Tests << get values, dt1:Reference << get values);
For(i = 1, i <= N Items(colist), i++,
	If(Contains(aa_refs, colist[i]),
		Report(vc[i])[Framebox(1)] << DispatchSeg(CustomStreamSeg(3), {Line Width(2)});
		Report(vc[i])[AxisBox(1)] << {Add Ref Line(aa_refs[colist[i]], "Solid", "Green", "RTS", 2)};
Here is a slightly different solution, reading the reference table directly
Clear Globals();
//dt = Open( "Data table.jmp" ); // Open data table
dt = Data Table( "data table" );
colist = {};
	// Var Chart
	X( :Wafer ID ),
	Std Dev Chart( 0 ),
//dt1 = Open( "Reference table.jmp" );
dt1 = Data Table( "reference table" );
xb = Column( dt1, "Reference" ) << getValues;
	//Report( vc[i] )[Framebox( 1 )] << DispatchSeg( CustomStreamSeg( 3 ), {Line Width( 2 )} );
	testVal = Word( -2, Report( vc[i] )[Outline Box( 2 )] << get title, " " ) || " " || Word(
		-1,
	testRow = dt1 << get rows where( :tests == testVal );
	If( N Rows( testRow ) > 0,
		Report( vc[i] )[AxisBox( 1 )] << Add Ref Line( dt1:Reference[testRow[1]], "Solid", "Green", "RTS", 2 )
There are a couple of issues.
  1. Different platforms have different Tree Structures because they have different output structures.  Therefore the mapping to the different objects within the output is different.
  2. You specify dt as the pointer to the "Data table", but later in the script, you attempt to execute the Overlay Plot, pointing to a data table referenced by a variable dt2, that does not exist in your code.
  3. In you code that creates the Associative Array, you use a variable from your Reference Data Table, called Reference.  In the sample data you provided in the Optimize Loop Discussion, the variable in that data table is called Mean.
Below is a modification of your code that produces the following output
dt=data table("Data Table");
dt1=data table("Reference data table");
colist = {};
	// Overlay Plot
		vc = dt << Overlay Plot( Y( Eval( colist ) ), No Overlay( 1 ),Ungroup Plots( 1 ) );
aa_refs = Associative Array(dt1:Tests << get values, dt1:mean << get values);
For(i = 14, i <= N Items(colist), i++,
		Report(vc)[AxisBox(1)] << Add Ref Line(aa_refs[colist[i]], "Solid", "Green", "RTS", 2);
Please take the time to read up on Display Trees in the Scripting Guide, available in the JMP Documentation Library, under the Help pull down menu.
colist = {};
	// Var Chart
	Y((Eval(colist))),
	X(:Wafer ID),
	Show Range Bars(0),
	Std Dev Chart(0),
	Points Jittered(1)
Clear Globals();
colist = {};
	// Var Chart
	X( :Wafer ID ),
	Std Dev Chart( 0 ),
		-1,
Jackie_
Hi @jthi ,
I tired your code on overlay plots but there's seems to an error. Any suggestions?
colist = {};
	// Overlay Plot
		vc = dt2 << Overlay Plot( Y( Eval( colist ) ), No Overlay( 1 ),Ungroup Plots( 1 ) );
colist = {};
	// Overlay Plot
