joydeepb83
Add a new value to rows of an existing column
Hi, I am new to JSL . I am trying to write a code do achieve the following.
I have 4 different JMP table. I am comparing each row of column 1 of Table 1 with column 1 of the remaining three table.
If any entry/row of Coulmn 1 /table 1 matches with column 1 of Table 2 , It assigns Character say- Group1 to the row in table 1/ Column 4.
Similarly if any row of column 1/tale1 matches with column1 of table 3 and table 4 then it assigns a character say- Group 2 in table 1/column 4.
I am successfully creating column 4 and after comparison with table 2.
However I am finiding it difficulty to update the same column 4 with Group2 when I am comparing the rows of table1 /column1 with table 3/column1.
Could anybody please help?
*More specifically, how can I update my existing column with new character string for given condition. as I cant use -new column for that.*
Thansk
jodyeep
Re: Add a new value to rows of an existing column
Here are a couple of examples that I hope will give you a leg up with the script you are working on
dt1 = New Table( "Table 1", New Column( "Col A", character, values( {"A1", "A2", "A3"} ) ) );
dt2 = New Table( "Table 2", New Column( "Col B", character, values( {"B1", "B2", "B3"} ) ) );
dt3 = New Table( "Table 3", New Column( "Col C", character, values( {"C1", "C2", "C3"} ) ) );
If( dt1:Col A[1] == "A1",
	dt2:Col B[3] = "Group 1"
If( dt2[2, 1] == "B2",
	Data Table( "Table 1" ):Col A[2] = "Looking Good"
 Here is a modification of your script that I believe will simplify the code
names default to here(1);
dt3 = Open( "\\Table 2" );
dt6 = Open( "Table 1" );
dt6 << New Column( "Group",
	Character)
m = N Rows( dt6 );
n = N Rows( dt3 );
For( i = 1, i <= m, i++,;
	For( j = 1, j <= n, j++,
		If( Column( dt6, "Core ID" )[i] == (Column( dt3, "PC_ID" )[j]),
			dt6:Group[i] = "Group 1"
dt6 << save( "Table1" );
//Close( dt3, nosave );
//Close( dt6, nosave );
joydeepb83
Hi Jim.
Thanks a lot for your help. The modification worked and got lot simplified.
Thanks
Joydeep
