Jackie_
Add/Subtract values from two jmp files
@txnelson @pmroz
I need help to offset the data set using the reference value in JSL
First table contains reference value
Second table contains strips tested measurements
I want to subtract mean of strip A from the reference data table and then add to to the data set
for example :
step1. the mean value for strips A for current = (10+3)/2 = 6.5. So, 400 - 6.5 = 393.5 and likewise for other strips
step2. Add 393.5 to the 2nd data table of strip A >> 393.2 + 10 = 403.2 and likewise for other strips
The final table should have following values:
Refer attached file for details.
Thank you for your help!
This what I tried:
dt = Current data table();
dtOffset = Open(Limits);
colList = dt << get column names(string);
For( i = 1, i <= N Items( colList ), i++,
	theRow = dtOffset << get rows where( dtOffset:Tests == colList[i] );
	show(i,nrows(therow));
	If( N Rows( theRow ) == 1,
		offset = dtOffset:Offset[theRow[1]];
		For( k = 1, k <= N Rows( dt ), k++,
			Column( dt, i )[k] = Column( dt, i )[k] + offset
15 REPLIES 15
Re: Add/Subtract values from two jmp files
The calculation of "measure" can not be calculated.  You have written a line of JSL that assumes that it is looping through a data table, but no looping through the rows is happening.
Jackie_
Thanks, @txnelson
I used For each rows syntax but the loop takes 40 min to complete. Any alternate way?
For( c = 1, c <= N Col( dt2 ) -1, c++,
	theMatrix = [];
	name = Column( Col_List1[c] ) << Get name;
	if (Contains( Col_List1[c], "Current"),
	//For( r = 1, r <= N Rows( dt2 ), r++,
For Each Row(
r = dt2 << get rows where(dt2:sitenumber == sitenum[1]); //mean = dt1:Mean[dt1 << Get Rows Where( :Tests == name )]; mean = column(dt2, Col_list1[c]) << get property("theMean"); //measure = mean - Col Mean( If( dt2:Strips == dt2:Strips[r], Column( dt2, c ), . ) ); measure = mean - Col Mean(as Column( dt2, c ),:Wafer ID); theMatrix = theMatrix || Column( dt2, c )[r] + measure; ); Column( dt2, c ) << Set Values( theMatrix ); ););
Jackie_
any advice Jim?
Your code is confusing to me.  When you have
     For Each Row
each separate row within the data table is processed.
When the Get Row Where() is used, it is only passing through the data once.  Can you provide a sample of the results you are expecting?
Jackie_
@txnelson
Below is the Screen short of the results that I am expecting. I have attached the final result data table
Here are the steps:
1. Read data table and reference data table
2. Generate a new window to select site number,
3. Based on the user input (Site Number 1 or 2), align those data to the reference data table values
 Take mean by wafer Id, apply the offset to the main data table
Clear globals();
Clear log();
dt1 = Data table( "Reference data table" );
dt2 = Current data table(); /// Select Data table.jmp
For(i=1,i<=nrows(dt1),i++,
	theTest = dt1:Tests[i];
	try(column(dt2,theTest) << set property("TheMean", dt1:Mean[i]));
New window( "", modal,
			ct = checkbox({"1","2"}),
			Buttonbox ("Ok",
				get = ct << Get Selected ();
sitenum = Transform Each({str}, get, Num(str));
Col_List1 = dt2 << Get Column Names( "String" );
//if (!contains(Col_List1, "SiteNumber"),
     // dt2 <<New Column("SiteNumber", "Numeric", "Continuous", <<Set Each Value( 1 ) );
	theMatrix = [];
	if (Contains( Col_List1[c], "Current 1.1") | Contains( Col_List1[c], "Current 2.1") | Contains( Col_List1[c], "Voltage 1.1"),
	For each row(
r = dt2 << get rows where(dt2:sitenumber == sitenum[1]); /// something needs to change here ****&&&**&&&&**&&& //mean = dt1:Mean[dt1 << Get Rows Where( :Tests == name )]; mean = column(dt2, Col_list1[c]) << get property("theMean"); //measure = mean - Col Mean( If( dt2:Strips == dt2:Strips[r], Column( dt2, c ), . ) ); measure = mean - Col Mean(as Column( dt2, c ),:Wafer ID); theMatrix = theMatrix || Column( dt2, c )[r] + measure; ); Column( dt2, c ) << Set Values( theMatrix ); ););
Jackie_
@txnelson
can you identify what's going wrong
