SpannerHead
Add Script to Existing Script Group
As usual, not sure how I got here but I have a script that groups the embedded scripts in a JMP table if they contain the word "History" in the title.  I have a script "Split Table" that I embed later that I would like to add to the "History" group of scripts.  Is there an easy way to do that without disassembling the group in the first place?
lstScripts = Current Data Table() << Get Table Script Names;
History_scripts = {};
For( j = 1, j <= N Items( lstScripts ), j++,
	If( Contains ( lstScripts[j] , "History" ),
		Insert Into( History_scripts, lstScripts[j] )
Show(History_scripts);
Current Data Table() << Group Scripts( History_scripts ) << rename script group( "Tool History etc.", "History");
Slán
SpannerHead
SpannerHead
Re: Add Script to Existing Script Group
Thanks Hogi.  Somehow I'm not getting that to work (amateur hour probably).  I'm using this and it works.
	If( Contains( lstScripts[j], "Split Table" ),
Current Data Table() << Group Scripts( History_scripts );
Slán
SpannerHead
It looks like you will need to get the names of the scripts in the history group using
     Get Script Group
Then ungroup the scripts using
     Ungroup Scripts
Then add your the script name that you want to add to the history group
If the history group name list is hisgp
     insert into(hisgp, <the new script name to be added>(
Then create the history group using the updated list using
     Group Scripts
Level XIII
Hm , I did not find such a function.
But it's easy to generate it:
dt << group scripts(
	"myGroup",
	{"Graph Builder Smoother Line", "Graph Builder Line and Bar Charts",
	"Graph Builder Line Chart", "Graph Builder Heat Map"}
insert Script = Function( {dt, groupName, scriptName},
//{default local},
	myList = dt << get script group( groupName );
	Insert Into( myList, scriptName );
	dt << group scripts( groupName, mylist );
insert Script( dt, "myGroup", "Logistic" )
Level XIII
Now I found it:
	"myGroup",
dt << group scripts("myGroup", "Logistic")
Level XIII
"I"
... actually it was him:
And now I remember ...
I accidentally detected this trick and used it in
 https://marketplace.jmp.com/appdetails/Graph+Builder+Toolbar  / SendToPowerpoint to add scripts of exported graphs to  hogi_1-1737069466419.png
SpannerHead
Slán
SpannerHead
