Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
In the data table, right click on SN in the column panel, and select Label/UnLabel. All columns that have the Label RowState set, will show up when you mouse over a data point the control chart.
