See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
Add SN to IMR control chart.
ConfidenceOwl94
How can I assign SN(from column) to IMR chart instead of raw number and subgroup.
Re: Add SN to IMR control chart.
In the data table, right click on SN in the column panel, and select Label/UnLabel.  All columns that have the Label RowState set, will show up when you mouse over a data point the control chart.
ConfidenceOwl94
Thanks
