frankderuyck
Add Random Seed to prediction formula
I would like make a reproducible simulation formula by adding a the same random number to a prediction formula .Guess this is possible with Random seed? I olnly find a very brief explanation in JMP help; how to add this random seed to a formula?
13 REPLIES 13
frankderuyck
Re: Add Random Seed to prediction formula
Remark: there is a selectivity > 100%, still have to adjust formula a bit to keep results < 100%
If you can't add that random value column to the table which students are using, I think you could use Random Reset(Row()) (you can change the Row() to something else, but it should still be Row() dependent and not randomized, so Row()*Row() or Row() + 10 are for example fine).
Column 8 just demonstrates the random reset + random normal part
frankderuyck
Great, works fine, thank Jarmo!
Mauro_Gerber
A small input, I use this to prevent the constant reset of the seed:
If( Row() == 1,
	Random Reset( 500 )
Random Normal( 5, 0.5 );
After the reset, the sequence is always the same "random" numbers within a JMP version.
"I thought about our dilemma, and I came up with a solution that I honestly think works out best for one of both of us"
- GLaDOS
