Anja_W
Add Outline Boxes to Window with variables
I try to add several Outline Boxes to a window with parameters which are stored in lists. I use a For-Loop to append the boxes. For the title this works just fine. However, if I draw lines it does not work. Below is a minimal example which I would like to get to work.
I'm thankful for any idea what I should change and what I'm doing wrong.
Best,
Anja
::lineList = {10, 20, 30};
::titleList = {"Title 1", "Title 2", "Title 3"};
w = New Window("My Test Window", myBox = Outline Box("My Test"));
For(i = 1, i <= 3, i++,
	myBox << Append(Outline Box(titleList[i], Graph Box(H Line(lineList[i]))))
Re: Add Outline Boxes to Window with variables
You can check how your Graph Box looks like by opening Customize menu
You can see that the value isn't there but rather variablename. You can for example use Eval(EvalExpr()) to avoid that issue
	Eval(EvalExpr(
		myBox << Append(
				H Line(Expr(lineList[i]))
	Eval(EvalExpr(
		myBox << Append(
Anja_W
Thank you very much! Now it works just fine as I would like it.
