ARIMA Time Series by ACF, PACF
How do you use the time series ACF and PACF plots to suggest the nonseasonal and seasonal AR components of the ARIMA model?
Peter_Bartell
Level VIII
Re: ARIMA Time Series by ACF, PACF
Generally I look at these plots to see which lag(s) have the highest correlation coefficients to help determine differencing order for the AR component and seasonal interval if I'm contemplating some sort of seasonal ARIMA model. I also try to use some process knowledge to validate, in a non-statistical sense, my differencing and seasonal interval guesses. For example...if I were monitoring temperature in my home, controlled by a thermostat, on a minute by minute basis, I'd suspect a differencing order close to 1 to be the best. If I were monitoring my home's monthly natural gas consumption, I'm guessing that a seasonal lag component would be 12 months out in time. Seriesg.jmp in the JMP Sample Data Directory is a good sample data set to illustrate these concepts.
Peter_Bartell
Level VIII
Ok, thx. This works.
Peter_Bartell
Level VIII
Glad to help!
