kd_kel
ANOM
I have an ANOM summary report I generated in JMP. I wanted to extract the Group means in each row of the report and save to a new data table (Run Chart) using JSL scripting, any help ?
Re: ANOM
Below are few good options
  1. Use make into datatable and concatenate
  2. Get values into list/matrix, add as many rows as you have in those and use data table subscripting
And here is one possible script for the make into datatable + concatenate
dt = Open("$SAMPLE_DATA/Drug.jmp");
dt_results = New Table("Results",
	Add Rows(0),
	New Column("FA", Character, Nominal),
	New Column("Pre", Numeric, Continuos),
	New Column("Post", Numeric, Continuos),
	New Column("Shift", Character, Nominal),
	New Column("Date", Numeric, Continuos)
ow = dt << Oneway(Y(:y), X(:Drug),
	ANOM(1, Show Summary Report(1), Point Options("Show Needles"))
tb = Report(ow)[Outline Box("Analysis of Means Summary"), Table Box(1)];
dt_ow = tb << Make Into Data Table;
Column(dt_ow, "Lower Limit") << Set Name("Pre");
Column(dt_ow, "Group Mean") << Set Name("Post");
dt_ow << Delete Columns({"Level", "Group N", "Upper Limit", "Limit Exceeded"});
dt_results << Concatenate(
	dt_ow,
	"Append To First Table"
Close(dt_ow, no save);
Re: ANOM
How does your run_chart_table look like? You could maybe use << Make Into Data table to the Oneway result table and concatenate that.
kd_kel
Re: ANOM
I want to assign the group means (pre and post group means )  from the anom summary report table to variables and then paste into pre and post columns of the data table below.
Re: ANOM
	Add Rows(0),
	dt_ow,
kd_kel
Re: ANOM
Thanks jthi !
