Hi @Luca_Indrizzi,
From the screenshots you give, everything seems normal to get to the results you expect.
How did you set up the blocking factor ? Did you set up as 8 runs per block (to have a 2^3 factorial design in each block) ? :
If yes, specifying 16 runs and main effects in the model should give you what you expect :
Here is the script if you want to generate the same design :
DOE(
Custom Design,
{Add Response( Maximize, "Y", ., ., . ),
Add Factor( Continuous, -1, 1, "X1", 0 ),
Add Factor( Continuous, -1, 1, "X2", 0 ),
Add Factor( Continuous, -1, 1, "X3", 0 ), Add Factor( Blocking, 8, "X4" ),
Set Random Seed( 1874557131 ), Number of Starts( 1 ), Add Term( {1, 0} ),
Add Term( {1, 1} ), Add Term( {2, 1} ), Add Term( {3, 1} ), Add Term( {4, 1} ),
Add Alias Term( {1, 1}, {2, 1} ), Add Alias Term( {1, 1}, {3, 1} ),
Add Alias Term( {2, 1}, {3, 1} ), Set Sample Size( 16 ), Simulate Responses( 0 ),
Save X Matrix( 0 ), Make Design}
And I attached the datatable (with colors!) for you to have a look.
If you want to have the full factorial design, you need to specify 2-factors interactions in the model, and with the same procedure, you'll end up with the full factorial design replicated once in two blocks like you expect :
Here is the script to generate it :
DOE(
Custom Design,
Set Random Seed( 1421844496 ), Number of Starts( 2 ), Add Term( {1, 0} ),
Add Term( {1, 1}, {2, 1} ), Add Term( {1, 1}, {3, 1} ),
Add Term( {2, 1}, {3, 1} ), Set Sample Size( 16 ),
Optimality Criterion( "Make A-Optimal Design" ),
"A-Optimality Parameter Weights"n( [1 1 1 1 1 1 1 1] ), Simulate Responses( 0 ),
Save X Matrix( 0 ), Make Design, Set Run Order( Randomize within Blocks ),
Make Table}
And datatable is attached as well.
Another option is to create the 8-runs factorial design, and then use the platform "Augment Design" to replicate the runs once. But you'll have to introduce in your final datatable a column indicating the block/part of the design, and set up accordingly (and manually) the column data type (character),modeling type (Nominal) and properties needed : ValueOrder (1 for block 1 and 2 for block 2), RunsperBlock (8), Design Role (Blocking) and Factor Changes (Easy)
Hope this will help you,
Victor GUILLER
