rshehadah
1 second vertical lines
I have a graph builder graph. How can I add vertical reference lines every 1 sec time interval?
Thank you,
Rami
jules
Re: 1 second vertical lines
Hi @rshehadah,
I would use Grid Lines for that since your spacing is regular. If you double click the X-Axis to enter the Axis Settings, you can toggle gridlines on the top right. Major gridlines are displayed at each value based on the increment. Minor gridlines are placed at each minor tick. axis.pnggb.png
I hope this helps!
@jules
jules
Hi @rshehadah,
I hope this helps!
@jules
