lala
Level IX
怎样用脚本计算不同字符串中字符相同的个数。
怎样用脚本实现将数据表的内容与第二个表中内容匹配的字符数量,不考虑顺序 、相符合数据最多的返回第二个表的行号。
我只会编写简单的循环比较。
如果要比较的字符串数量很多时、怎样才能较快速。
谢谢!
Re: 怎样用脚本计算不同字符串中字符相同的个数。
If no duplication is allowed you could try using associative arrays and their set operations:
dt = New Table("demo",
	Add Rows(4),
	New Column("A", Character, "Nominal", Set Values({"KDBAC", "FLGHEK", "ONLCQR", "WVTZXR"})),
	New Column("B", Character, "Nominal", Set Values({"ROMNLQ", "DFBACE", "LKGHJK", "WVTZYX"}))
// Create lookup associative array, with row number as key and value as associative array with
// keys as characters in row. This will be used in union operations
aa_lookup = Associative Array();
For Each({val, idx}, dt:B << get values,
	aa_lookup[idx] = Associative Array(Eval List(Words(val, "")));
// Create collection column
dt << New Column("C", Numeric, Continuous);
For Each Row(dt,
	best_match = 0;
	max_row = .;
	For Each({{key, val}}, aa_lookup,
		cur_aa = Associative Array(Eval List(Words(:A, "")));
		cur_aa << Intersect(val);
		cur_match = N Items(cur_aa);
		If(cur_match > best_match,
			best_match = cur_match;
			max_row = key;
	:C = max_row;
6 REPLIES 6
lala
Level IX
For example,
string for the first table
"KDBAC"
"FLGHEK"
"ONLCQR"
"WVTZXR"
String for the second table
"ROMNLQ"
"DFBACE"
"LKGHJK"
"WVTZYX"
lala
Level IX
Can there be duplicated characters in the strings?
	Add Rows(4),
For Each Row(dt,
	best_match = 0;
	max_row = .;
			max_row = key;
	:C = max_row;
lala
Level IX
JMP Pro 15.2,
Thank jthi!
If you are using JMP15 you have to change For Each to For-loop.
