lala
Level IX
怎样将二进制文件中的指定字节转化为浮点数字?
例如将图中的第一行04——07字节转化为浮点数字,感谢专家!
正确的结果是 : 1006.27
二进制文件如下:
598A0F0548917B44F6C87B44855B7B44D7637B44DA57BE45140B000000000000
12 REPLIES 12
lala
Level IX
Re: 怎样将二进制文件中的指定字节转化为浮点数字?
我试着这样修改、但不成功。
r = N Row( years );
dt = As Table(
	years,
	months,
	days,
	seconds,
	float4[r - 479 :: r, 2 :: 6], ////
	integer4[r - 479 :: r, 7 :: 8], ///
	<<columnnames( {"year", "month", "day", "second", "v1", "v2", "v3", "v4", "v5", "xx", "reserved"} )
Craige_Hales
was there a message in the log?
all of those arrays (years,months,days,seconds) will need the same treatment: years[r-479::r], for example.
It might be easier to delete unwanted rows from the table after creating it. Try using the date column to select the range you care about.
Craige
lala
Level IX
看到这个图形、我提两个疑点 :
1、为了图形连续、不受日期间隔的影响、有什么简单方法实现。我只会使用行号列来作为X轴
Column( "reserved" ) << Formula( Row() );dt << run formulas;Column( "reserved" ) << deleteFormula;
	Variables( X( :reserved ), Y( :v5 ), Y( :v4 ), Y( :v3 ), Y( :v2 ), Y( :v1 ), Y( :xx ) ),
2、其实这个数据股票的交易数据。
JMP能否直接制作象这种日本蜡烛图。在excel中能简单制作这种图
非常感谢!
