lehaofeng
如何根据用户输入的值自动的改变制表平台里的合格率?
谢谢各位大佬,我是一个新手,求问,如何把用户输入的比较符号,还有数值,纳入JSL计算,我用eval(parse()),始终实现不了,谢谢。
names default to here(1);
New Window( "合格率报表",
	Data Filter Context Box(
		H List Box(
			dfsb = Current Data Table() << Data Filter( Local ),
			Platform(
				Current Data Table(),
				V List Box(
					Outline Box( "请输入所有参数规格限",
						Lineup Box( N Col( 3 ), Spacing( 5 ),
							Panel Box( "age",
									Text Box( "upper " ),
									dluf = Combo Box( {"<=", "<"} ),
									dlu = Number Edit Box(15),
									Text Box( "lower " ),
									dlbf = Combo Box( {">=", ">"} ),
									dlb = Number Edit Box(-3)
							Panel Box( "height",
									dauf = Combo Box( {"<=", "<"} ),
									dau = Number Edit Box(),
									dabf = Combo Box( {">=", ">"} ),
									dab = Number Edit Box()
							Panel Box( "weight",
									dbuf = Combo Box( {"<=", "<"} ),
									dbu = Number Edit Box(),
									dbbf = Combo Box( {">=", ">"} ),
									dbb = Number Edit Box()
							Button Box( "确定",
							          //获取规格限数字
								ageu = dlu << get;
								agel = dlb << get;
								heiu = dau << get;
								heil = dab << get;
								weiu = dbu << get;
								weil = dbb << get;
							          //获取规格限数字是否包含
								aguf = ((dluf << XPath( "//ComboBox" )) << get selected)[1];
								aglf = ((dlbf << XPath( "//ComboBox" )) << get selected)[1];
								heuf = ((dauf << XPath( "//ComboBox" )) << get selected)[1];
								helf = ((dabf << XPath( "//ComboBox" )) << get selected)[1];
								weuf = ((dbuf << XPath( "//ComboBox" )) << get selected)[1];
								welf = ((dbbf << XPath( "//ComboBox" )) << get selected)[1];
						dt << Tabulate(
						Set Format(
							Mean(
								:Name( "age" )(6, "Best"),
								:Name( "height" )(6, "Best"),
								:Name( "weight")(6, "Best"),
			                    Analysis Columns(
									Transform Column( "age rate", eval(parse("if(:age"||aglf|| char(agel)|| ":age"||aguf||char(ageu)||",1,0)")) ,
				Format( 9, 2, "Percent" )
								Analysis Columns(
									Transform Column( "height rate", Formula( eval(parse("if(:height"||helf|| char(heil)|| ":height"||heuf||char(heiu)||",1,0)")) ) ),
				//强行修改格式
								Analysis Columns( Transform Column( "weight rate", Formula( eval(parse("if(:weight"||welf|| char(weil)|| ":weight"||weuf||char(weiu)||",1,0)")) ) ), Format( 9, 2, "Percent" ) )
							N( 9, "Best" )
						Add Table(
							Column Table(
			//具体固定统计列
								Analysis Columns( :Name( "age" ), :Name( "weight" ), :Name( "height" ) ),
								Statistics( Mean, Range )
		//调整样本量列的实际位置
							Column Table( Statistics( N ) ),
							column table(Analysis Columns(
									Transform Column( "rate age", Formula( eval(parse("if(:age"||aguf|| char(agel)|| ":age"||aguf||char(ageu)||",1,0)"))) ) ),Statistics( Mean )
							Column Table(
								Analysis Columns( Transform Column( "height rate", Formula( eval(parse("if(:height"||helf|| char(heil)|| ":height"||heuf||char(heiu)||",1,0)")) ) ) ),
								Statistics( Mean )
							Column Table(
								Analysis Columns( Transform Column( "weight rate", Formula( eval(parse("if(:weight"||welf|| char(weil)|| ":weight"||weuf||char(weiu)||",1,0)")) ) ) ),
								Statistics( Mean )
		//临时固定类别列,且可以通过拖拽进行增删
							Row Table( Grouping Columns( :sex ) )
Re: 如何根据用户输入的值自动的改变制表平台里的合格率?
There are several approaches. The following is an example that uses the eval insert function.
This page is also helpful to understand expression.
create tabulate = Expr(
	Parse(
		Eval Insert(
	tabulate box = dt << Tabulate(
		Set Format(
			Mean(
				:Name( "weight" )(6, "Best"),
				Analysis Columns(
					Transform Column(
						"age rate",
						Formula ( if(:age ^aglf^ ^agel^ & :age ^aguf^ ^ageu^ ,1,0) ),
				Analysis Columns(
					Transform Column(
						"height rate",
						Formula(  if(:height ^helf^ ^heil^ & :height ^heuf^ ^heiu^ ,1,0) )
    //强行修改格式
				Analysis Columns(
					Transform Column(
						"weight rate",
						Formula(  if(:weight ^welf^ ^weil^ & :weight ^weuf^ ^weiu^ ,1,0) )
			N( 9, "Best" )
		Add Table(
			Column Table(
   //具体固定统计列
  //调整样本量列的实际位置
			column table(
				Analysis Columns(
					Transform Column(
						"rate age",
						Formula(  if(:age ^aguf^ ^agel^ & :age ^aguf^ ^ageu^ ,1,0) )
				Statistics( Mean )
			Column Table(
				Analysis Columns(
					Transform Column(
						"height rate",
				Statistics( Mean )
			Column Table(
				Analysis Columns(
					Transform Column(
						"weight rate",
				Statistics( Mean )
nw = New Window( "合格率报表",
		H List Box(
			Platform(
				V List Box(
							Panel Box( "age",
									dlu = Number Edit Box( 15 ),
									dlb = Number Edit Box( -3 )
									dau = Number Edit Box( 15 ),
									dab = Number Edit Box( 1 )
									dbu = Number Edit Box( 15 ),
									dbb = Number Edit Box( 1 )
							Button Box( "确定",
                 //获取规格限数字
								ageu = dlu << get;
								agel = dlb << get;
								heiu = dau << get;
								heil = dab << get;
								weiu = dbu << get;
								weil = dbb << get;
                 //获取规格限数字是否包含
								Try( tabulate box << delete );
								tabulate << append( Eval( create tabulate ) );
					tabulate = V List Box();
	Parse(
		Eval Insert(
		Set Format(
			Mean(
				Analysis Columns(
					Transform Column(
						"age rate",
				Analysis Columns(
					Transform Column(
						"height rate",
    //强行修改格式
				Analysis Columns(
					Transform Column(
						"weight rate",
			N( 9, "Best" )
		Add Table(
			Column Table(
   //具体固定统计列
  //调整样本量列的实际位置
			column table(
				Analysis Columns(
					Transform Column(
						"rate age",
				Statistics( Mean )
			Column Table(
				Analysis Columns(
					Transform Column(
						"height rate",
				Statistics( Mean )
			Column Table(
				Analysis Columns(
					Transform Column(
						"weight rate",
				Statistics( Mean )
		H List Box(
			Platform(
				V List Box(
							Panel Box( "age",
							Button Box( "确定",
                 //获取规格限数字
								ageu = dlu << get;
								agel = dlb << get;
								heiu = dau << get;
								heil = dab << get;
								weiu = dbu << get;
								weil = dbb << get;
                 //获取规格限数字是否包含
lehaofeng
非常感谢,能够请教一下吗?为什么“||"要换成 “&”?
It seems that your orginal formula is like this "If(:age >= 8:age < 20, 1, 0);".
I thought you needed an and operator in the formula. "If(:age >= 8 & :age < 20, 1, 0);".
If you use the eval insert function, you don't need to add "||" in this example.
aglf = ">=";
agel = 8;
aguf = "<";
ageu = 20;
example1 = eval insert("if(:age ^aglf^ ^agel^ & :age ^aguf^ ^ageu^ ,1,0)");
Show( example1 );
