lala
Level VIII
如何将这些内容加入JSL、实现用JSL下载数据?
有个网址是POST方式的数据、
我已经用Chrome分析了它的URL、并按"Copy as cURL (bash)"复制了
请教专家:
如何将这些写入JSL中、才能下载这个网址的数据?
非常感谢!
stan_koprowski
Re: 如何将这些内容加入JSL、实现用JSL下载数据?
Hi @lala,
You can do something like the following using the information provided--
stock_n = "002466";
page = "1";
stock_page_str = "&stockno=" || stock_n || "&pageIndex=" || page;
base_url = "https://www.wlstock.com/ajaxRequrst/StockFundFlowAjax.ashx?act=3";
url = base_url || stock_page_str;
stock_request = New HTTP Request(
	URL( url ),
	Method( "POST" ),
	Headers(
		{"Content-Type, application/x-www-form-urlencoded; charset=UTF-8"},
		{"Origin, https://www.wlstock.com"},
		{"Accept-Language", "zh-CN,zh;q=0.9,en;q=0.8,zh-TW;q=0.7"},
		{"Sec-Fetch-Site", "same-origin"},
		{"Cookie",
		"__utmz=1.1629363027.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); HWWAFSESID=5c23e883e2470897bb; HWWAFSESTIME=1629383287343; Hm_lvt_16ae844519b6d6a721828d6914c625ff=1629366513,1629367214,1629369083,1629383289; Hm_lpvt_16ae844519b6d6a721828d6914c625ff=1629383289; __utma=1.1098944855.1629363027.1629369083.1629383289.3; __utmc=1; __utmt=1; __utmb=1.2.10.1629383289"
		{"Accept-Encoding", "gzip, deflate, br"},
		{"Referer",
		"https://www.wlstock.com/hudong/stockfundflow.aspx?stockno=002466"},
		{"User-Agent",
		"Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.108 Safari/537.36"
		{"X-Requested-With", "XMLHttpRequest"},
		{"Sec-Fetch-Mode", "cors"},
		{"Accept: application/json, text/javascript, */*; q=0.01"}
json = stock_request << Send;
If( stock_request << Is Success,
	dt = JSON To Data Table( json );
	dt << Set Name( "Stock_Number_" || stock_n );
cheers,
Stan
8 REPLIES 8
lala
Level VIII
回复: 如何将这些内容加入JSL、实现用JSL下载数据?
复制所得到的内容
curl 'https://www.wlstock.com/ajaxRequrst/StockFundFlowAjax.ashx?act=3' -H 'Connection: keep-alive' -H 'Accept: application/json, text/javascript, */*; q=0.01' -H 'Origin: https://www.wlstock.com' -H 'X-Requested-With: XMLHttpRequest' -H 'User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.108 Safari/537.36' -H 'Content-Type: application/x-www-form-urlencoded; charset=UTF-8' -H 'Sec-Fetch-Site: same-origin' -H 'Sec-Fetch-Mode: cors' -H 'Referer: https://www.wlstock.com/hudong/stockfundflow.aspx?stockno=002466' -H 'Accept-Encoding: gzip, deflate, br' -H 'Accept-Language: zh-CN,zh;q=0.9,en;q=0.8,zh-TW;q=0.7' -H 'Cookie: __utma=1.1098944855.1629363027.1629363027.1629363027.1; __utmz=1.1629363027.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); HWWAFSESID=4cf4679b97f4a3e6d6; HWWAFSESTIME=1629366513360; Hm_lvt_16ae844519b6d6a721828d6914c625ff=1629363027,1629363561,1629364787,1629366513; Hm_lpvt_16ae844519b6d6a721828d6914c625ff=1629366513; __utmc=1; __utmt=1; __utmb=1.30.10.1629363027' --data 'stockNo=002466&pageIndex=2' --compressed
这个是JSON的方式
    "data":"stockNo=002466&pageIndex=2",
    "method":"POST",
    "url":"https://www.wlstock.com/ajaxRequrst/StockFundFlowAjax.ashx?act=3",
    "headers":{
        "Accept":" application/json, text/javascript, */*; q=0.01",
        "Accept-Encoding":" gzip, deflate, br",
        "Accept-Language":" zh-CN,zh;q=0.9,en;q=0.8,zh-TW;q=0.7",
        "Connection":" keep-alive",
        "Content-Type":" application/x-www-form-urlencoded; charset=UTF-8",
        "Cookie":" __utma=1.1098944855.1629363027.1629363027.1629363027.1; __utmz=1.1629363027.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); HWWAFSESID=4cf4679b97f4a3e6d6; HWWAFSESTIME=1629366513360; Hm_lvt_16ae844519b6d6a721828d6914c625ff=1629363027,1629363561,1629364787,1629366513; Hm_lpvt_16ae844519b6d6a721828d6914c625ff=1629366513; __utmc=1; __utmt=1; __utmb=1.30.10.1629363027",
        "Origin":" https://www.wlstock.com",
        "Referer":" https://www.wlstock.com/hudong/stockfundflow.aspx?stockno=002466",
        "Sec-Fetch-Mode":" cors",
        "Sec-Fetch-Site":" same-origin",
        "User-Agent":" Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.108 Safari/537.36",
        "X-Requested-With":" XMLHttpRequest"
python的方式
import requests
headers = {
    'Connection': 'keep-alive',
    'Content-Type': 'application/x-www-form-urlencoded; charset=UTF-8',
    'Origin': 'https://www.wlstock.com',
    'Accept-Language': 'zh-CN,zh;q=0.9,en;q=0.8,zh-TW;q=0.7',
    'Sec-Fetch-Site': 'same-origin',
    'Cookie': '__utma=1.1098944855.1629363027.1629363027.1629363027.1; __utmz=1.1629363027.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); HWWAFSESID=4cf4679b97f4a3e6d6; HWWAFSESTIME=1629366513360; Hm_lvt_16ae844519b6d6a721828d6914c625ff=1629363027,1629363561,1629364787,1629366513; Hm_lpvt_16ae844519b6d6a721828d6914c625ff=1629366513; __utmc=1; __utmt=1; __utmb=1.30.10.1629363027',
    'Accept-Encoding': 'gzip, deflate, br',
    'Referer': 'https://www.wlstock.com/hudong/stockfundflow.aspx?stockno=002466',
    'User-Agent': 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.108 Safari/537.36',
    'X-Requested-With': 'XMLHttpRequest',
    'Sec-Fetch-Mode': 'cors',
    'Accept': 'application/json, text/javascript, */*; q=0.01',
data = 'stockNo=002466&pageIndex=2'
response = requests.post('https://www.wlstock.com/ajaxRequrst/StockFundFlowAjax.ashx?act=3', headers=headers, data=data)
ih
Super User (Alumni) ih
Hi lala,
Have a look at the function New HTTP Request.  More info can be found here Re: Importing Web Service Data: The New HTTP Request in JMP® 14 ( US 2018 231 )
Note that if you have existing python code that works you can call that directly using functions like Python Send()
lala
Level VIII
谢谢!
这个帖子我也学习过。我对于 POST的处理方法还是没有掌握。
未能找到解决方法。
lala
Level VIII
excel、VBA
Sub http_request()
    Dim winhttpObj As Object
    Dim resp as String
    Set winhttpObj = CreateObject("WinHttp.WinHttpRequest.5.1")
    With winhttpObj
    .Open "POST", "https://www.wlstock.com/ajaxRequrst/StockFundFlowAjax.ashx?act=3", False
    .setRequestHeader "Connection", "keep-alive"
        .setRequestHeader "Content-Type", "application/x-www-form-urlencoded; charset=UTF-8"
        .setRequestHeader "Origin", "https://www.wlstock.com"
        .setRequestHeader "Accept-Language", "zh-CN,zh;q=0.9,en;q=0.8,zh-TW;q=0.7"
        .setRequestHeader "Sec-Fetch-Site", "same-origin"
        .setRequestHeader "Cookie", "__utmz=1.1629363027.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); HWWAFSESID=5c23e883e2470897bb; HWWAFSESTIME=1629383287343; Hm_lvt_16ae844519b6d6a721828d6914c625ff=1629366513,1629367214,1629369083,1629383289; Hm_lpvt_16ae844519b6d6a721828d6914c625ff=1629383289; __utma=1.1098944855.1629363027.1629369083.1629383289.3; __utmc=1; __utmt=1; __utmb=1.2.10.1629383289"
        .setRequestHeader "Accept-Encoding", "gzip, deflate, br"
        .setRequestHeader "Referer", "https://www.wlstock.com/hudong/stockfundflow.aspx?stockno=002466"
        .setRequestHeader "User-Agent", "Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.108 Safari/537.36"
        .setRequestHeader "X-Requested-With", "XMLHttpRequest"
        .setRequestHeader "Sec-Fetch-Mode", "cors"
        .setRequestHeader "Accept", "application/json, text/javascript, */*; q=0.01"
	.Send "stockNo=002466&pageIndex=1"
    End With
    resp = winhttpObj.responsetext
End Sub
stan_koprowski
Hi @lala,
stock_n = "002466";
page = "1";
	URL( url ),
	Method( "POST" ),
	Headers(
		{"Cookie",
		{"Referer",
		{"User-Agent",
cheers,
Stan
lala
Level VIII
非常感谢!
lala
Level VIII
看来POST的变化较多的。
另一网址的数据POST结构有不同、用同样的分析不能下载。
我参考了社区的帖子、按stan的代码修改
query ="pxpageIndex=1&pageSize=50&clIndex=0&dlIndex=0";
base_url = "https://www.wlstock.com/ShuJu/StockFundFlowQuery.aspx";
url = base_url ;
	URL( url ),
	Method( "POST" ),
	QueryString( query )
可以下载数据、但JSON结构问题、得到的数据每行数据是重复多次的。
lwx228
Level VIII
cheers,
	URL( url ),
	Method( "POST" ),
