Ruth Hummel, Sr. Manager, Analytical Education, JMP
Join Ruth Hummel, Senior Manager of JMP Education, to examine the mind of JMP and to learn how to make the paradigm shift needed to think like a data explorer. Like Copernicus shifting from an earth-centered to a sun-centered understanding of the universe, when you start using JMP, you no longer see a problem-focused mess of a spreadsheet, filled with summary statistics and partial analyses side by side with raw data. Rather, you see a data table that is the center of the analysis universe. The columns become the cast of characters that you can assign to roles in various data stories, all connected back, dynamically, to that data table. New columns are created through formulas, depending on the old columns, often with a simple right-click and with JSL programming language that writes itself. JMP offers a connected, dynamic, progressive analysis experience, with richness and depth at your fingertips. It just takes a little paradigm shift to unlock the magic of JMP.
