Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
Let us know how you think the JMP User Community could be improved. Enter your suggestion or comment and vote on other suggestions by giving it a kudos. We want your feedback!
The insert JSL script button needs a bit of work. I would prefer if it didn't use a proportional font. Also the syntax colorization gets lost sometimes. Bottom line is that it doesn't match what you see in the JSL editor at all.
We've changed the font to be all monospaced. We will continue to make improvements to the color coding as we're able. We have to use simple regex to identify keywords and color them, so it will likely never match exactly. Would it be better to have no color coding?
With some recent changes to the User Community, we did some work to improve our syntax highlighting for JSL. You should now see a much closer match to the syntax highlighting that you would see in the Script Editor.
Let me know if something doesn't look right.
-Justin
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
