Community Wish List
Let us know how you think the JMP User Community could be improved. Enter your suggestion or comment and vote on other suggestions by giving it a kudos. We want your feedback!
Improve JSL script appearance
The insert JSL script button needs a bit of work.  I would prefer if it didn't use a proportional font.  Also the syntax colorization gets lost sometimes.  Bottom line is that it doesn't match what you see in the JSL editor at all.
4 Comments
Jeff_Perkinson
Community Manager
We've changed the font to be all monospaced. We will continue to make improvements to the color coding as we're able. We have to use simple regex to identify keywords and color them, so it will likely never match exactly. Would it be better to have no color coding?
pmroz
Color is very nice to have.  Plus it matches what you see in the JSL editor.
Jeff_Perkinson
Community Manager
Status changed to: Delivered
Hi @pmroz,
With some recent changes to the User Community, we did some work to improve our syntax highlighting for JSL. You should now see a much closer match to the syntax highlighting that you would see in the Script Editor.
Let me know if something doesn't look right.
-Justin
