Learn how to build custom Python data connectors and further customize JMP’s Data Connector Framework with the Python Data Connector Demo, available now in the JMP Marketplace!
Learn some foundational elements of JMP Scripting Language (JSL) and how to extend point & click automation into repeatable, shareable routines. Register. June 26, 2 p.m. US Eastern Time.
Let us know how you think the JMP User Community could be improved. Enter your suggestion or comment and vote on other suggestions by giving it a kudos. We want your feedback!
The insert JSL script button needs a bit of work. I would prefer if it didn't use a proportional font. Also the syntax colorization gets lost sometimes. Bottom line is that it doesn't match what you see in the JSL editor at all.
We've changed the font to be all monospaced. We will continue to make improvements to the color coding as we're able. We have to use simple regex to identify keywords and color them, so it will likely never match exactly. Would it be better to have no color coding?
With some recent changes to the User Community, we did some work to improve our syntax highlighting for JSL. You should now see a much closer match to the syntax highlighting that you would see in the Script Editor.
Let me know if something doesn't look right.
-Justin
