  • See how to use the JMP Marketplace – Free tools to expand JMP capabilities. Register. July 10, 2 pm US Eastern Time.
Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
Isabel26
Level III
how to scrip 'make tabulate into data table'
I think I am being nuts here. It should not be hard, but I just cannot make it work. I made a tabulate that I can click the option 'Make into data table', then save the data table. I want to script this so I can automate it. But no matter what I script, 'Make into data table' just won't work, either return me empty table, or error. Help is appreciated.
2 ACCEPTED SOLUTIONS
Accepted Solutions
jthi
Re: how to scrip 'make tabulate into data table'
Create a tabulate, fron red triangle menu choose make into datatable, from new table check source table script (right click + edit). This should give you a good idea how to script it:
(Data Table("Big Class") << Tabulate(
	Show Control Panel(0),
	Add Table(
		Column Table(Analysis Columns(:weight), Statistics(Mean)),
		Row Table(Grouping Columns(:sex))
)) << Make Into Data Table
Full example:
Names Default To Here(1);
dt = Open("$SAMPLE_DATA/Big Class.jmp");
tab = dt << Tabulate(
	Add Table(
dt_tab = tab << Make Into Data Table;
show(dt_tab);
//to close tabulate use
//tab << Close Window;
-Jarmo
jthi
I'm not sure but most likely you can add it like this:
dt_tab = tab << Make Into Data Table(Outputtable("test"));
and if that doesn't work you can set it after creation of the new table with:
dt_tab << Set Name("test");
-Jarmo
4 REPLIES 4
jthi
	Add Table(
Full example:
	Add Table(
show(dt_tab);
-Jarmo
Isabel26
Level III
It worked! Thanks. I guess if I want to add name to the new data table, I just need to add ' output table name( "NEW NAME")' some where?
jthi
-Jarmo
Isabel26
Level III
The first option works perfectly! Thanks so much!
