New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit. Register now, free of charge.
txnelson
Once a script is added or a discusssion is started they can not be deleted
Some times when responding to a discussion, I have posted my response, only to find that I have misread the discussion, and responded inappropriatly or falsely.  In that case, I want to delete my post.  There is no option to do that.
Also, if you post a script to a reply, and you want to delete it from your reply, it can not be deleted.
Jim
4 REPLIES 4
Jeff_Perkinson
Re: Once a script is added or a discusssion is started they can not be deleted
Yes, the permission to delete messages (even your own) is not enabled. If you have a message you'd like to delete, please notify me and I'll work with you on it.
As for not being able to edit a post if you've included a JSL script, I'm unable to reproduce that problem. Can you give me some steps to follow?
-Jeff
txnelson
If you go to the reply that I made to:
     Saving with filename
you will see an empty script box in the reply.  What I did was that I editied the reply I had made.  I placed a script into the reply.  I then posted the reply.  I then edited my reply and cut all of the contents from the script, and reposted.  The script was not deleted.  It now remains as an empty box.
Jim
Jeff_Perkinson
Just saw your post with an empty script to start. I assume that was the one that was causing a problem.
I edited it and removed the code block. To do that I used the HTML tab above the editor and deleted the <pre> </pre> tags that were causing the problem.
-Jeff
txnelson
I guess that is referred to as the pre/pre kluge  :-)
not the cleanest solution in the world
Jim
