  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
Wei1
Level II
New Window Opens Every Time When Open New File(Version 18.2)
Hi,
I am writing to report an issue with JMP 18.2.
Whenever I start the new file, a secondary window opens automatically in addition to the main workspace, which unnecessarily consumes system resources.
I have tried like Reset the file association for JMP
Unfortunately, none of these actions have resolved the problem.
Could you please advise if there are any additional steps or settings I can adjust to prevent the extra window from opening on launch?
Thanks
1 REPLY 1
Jflood
Level II
Re: New Window Opens Every Time When Open New File(Version 18.2)
not sure if you have resolved this.  I had the same issue and the notepad method discussed here resolved the issue.
Problem Note 52261: New instance of JMP® is opened each time a new file is opene... - JMP User Commu...
