  • See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
txnelson
I am attempting to change the title of an entry, and it keeps changing back to the original title
I have attempted to change the visible title to the Community Entry
How can I temporarily specify the current window in the script?
I have pasted in the new title of
How do I reference an already run platform's output report and the executable object that generated it?
After I post the edited entry, the entry changes back to the original title.  If I go back to edit the entry, it shows the changed title in the edit window.
Any idea what I can do to fix this?
Jim
4 REPLIES 4
Ryan_Gilmore
Re: I am attempting to change the title of an entry, and it keeps changing back to the original title
Hi @txnelson, it is related to the translation mechanism. Let me investigate to see what (if anything), can be done. Thanks.
txnelson
I was guessing the translator was causing the issue.  I even translated the text and pasted it into the Subject line, but that didn't fix it either
Jim
Ryan_Gilmore
To update a subject, the updated text must be in the same language of the body of the post. In this case, the subject should be entered in Chinese (Simplified). It is then a matter of time before the re-translation of the post occurs. The change will only affect the subject of the original post, not the replies. The subject of the replies will only be re-translated if a change is made (or the entire post re-submitted for translation, which only an administrator can do).
txnelson
OK.......I will change the subject to be entered in Simplified Chinese.
Jim
