Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
hogi
Level XIII
How to find "my" image album?
If a user doesn't know the ID of it's image album, is there a trick to find it?
https://community.jmp.com/t5/media/v4/gallerypage/tab/albums/page/1016
Ryan_Gilmore
Re: How to find "my" image album?
At the moment, not really. You could use the following URL structure,
https://community.jmp.com/t5/media/gallerypage/user-id/[user-id]/tab/all
I'll create a work item to add this to the profile page. Thanks.
6 REPLIES 6
I'm not sure if you could find it in older community layout but there are a lot of things that you cannot find anymore or are much harder to find (most likely this will improve at somepoint). My way of finding things from community is using google OR hoping that the URLs can still be accessed from browser's address bar.
For me google works for images but it might not for everyone
and from here I can click Albums to see all image albums
Other option is finding an image from community, opening it and clicking on the Public (username)
This will bring you to users image album and then you can again press Albums to see all available albums
hogi
Level XIII
@Ryan_Gilmore
is there any more direct way?
Ryan_Gilmore
hogi
Level XIII
great :)
thank you ...
Buttler
That’s an interesting question. I was also trying to locate my own image album in the community gallery and found it a bit confusing without knowing the album ID. It would be helpful if there was an easier way to navigate directly to a user’s albums from their profile. Looking forward to any tips from the community.
Ryan_Gilmore
To access your photos,
  1. Click your avatar in the upper right corner.
  2. Select My profile.
  3. Click View all under My Photos in the right side bar.
