  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Community Discussions
Got a question about using the JMP User Community? A complaint or a compliment? Post it here.
David_Burnham
Super User (Alumni)
Giving Kudos
I was just about to reply to a post when I saw that @txnelson had already made the same response (there's a surprise!).  I wanted to "Kudos" the response but there is no option.  There is an option to Kudos the "post" (i.e. the question) but that makes less sense to me.  Am I missing something?
-Dave
1 ACCEPTED SOLUTION
Accepted Solutions
Jeff_Perkinson
Re: Giving Kudos
The kudos button is back for replies now. I apologize for its brief absence. ;)
I'm not seing the strange counting behavior that @pmrozreports. Please let me know if it continues.
-Jeff
4 REPLIES 4
pmroz
Re: Giving Kudos
I noticed that as well.  I'd like to give credit to someone who posted a solution, but right now it's not possible because the Kudos button doesn't appear.
Another thing - the Kudos button has inconsistent behavior:
0 Kudos: click and 1 appears
2 Kudos: click and 1 appears(??)
Jeff_Perkinson
Re: Giving Kudos
-Jeff
pmroz
Re: Giving Kudos
I don't see the Kudos button for replies in the Discussion section.  Only for the first post.  This is the last reply that was posted on 11/3:
Jeff_Perkinson
Re: Giving Kudos
Save to Database is too slow (10k records per minute)​​ has a reply by msharp that reminded me of a performance enhancement scheduled for JMP 13.  (Thanks Jeff Polzin!)
Msharp mentions that the database update function is faster than another technique, but still not great.  (And see bryan.boone answer to the original question as well...another JMP 13 performance enhancement.)  I looked at the script (which is a clever way to use JSL and SQL) and saw it adds items to the end of a list, something like this:
// build forward
forwardList = {};
starttime = Tick Seconds();
For( i = 0, i < 30000, i++,
  Insert Into( forwardList, i )
stoptime = Tick Seconds();
Show( stoptime - starttime );
stoptime - starttime = 1.68333333334886; // JMP 12 time
that's really slow in JMP 12 and earlier.  The list is held internally by its first item, and the last item must be discovered by walking the length of the list.  InsertInto() adds to the end of the list by default. That leads to N^2 performance: doubling the length of the list quadruples the time.  There is a way to avoid it:
// build reverse
reverseList = {};
  Insert Into( reverseList, i, 1 )
reverseList = Reverse( reverseList );
stoptime - starttime = 0.0333333334419876;
that's better.  The insertinto() function is called with a 3rd argument of 1 to insert at the front of the list.  Notice the call to the reverse() function is also accounted for in the reported time.  And the answer is the same:
show( reverseList == forwardList);
reverseList == forwardList = 1; // good, same answer either way
Looking forward to JMP 13?  here it is:
// build forward
forwardList = {};
stoptime - starttime = 0.0166666668374091; // Jeff is amazing!
Long story short, if you have a JMP 12 script that is building a list of more than 100 or so items, insert at the front, then reverse.  JMP 13 will be fast either way.
-Jeff
