Byron Wingerd's Blog
Byron_JMP
Interactive HTML Nominal Logistic Regression Profiler Figure
The Nominal Logistic Regression Report has a  Profiler for showing the probability of a binomial outcome as a function of your model effects. This is a great figure, but when its exported using the "Interactive HTML" option, the figure is static. These are some quick notes on how to get around that problem.
 One of the things I love about the nominal logistic Profiler is that it shows the probability of one level over the other in a slick little boxed Y axis scale. Unfortunately this is key to why the figure doesn't export. So if you're willing to accept a Y-axis that shows the probability on a 0 to 1 scale for one of the two levels, which isn't a bad compromise, then give this a try next time you want to publish that interactive logistic regression figure.
Method 1: Remove the Response Probability Property before Graph>Profile
Step 1: In the Nominal logistic regression report, use the red triangle option to save the probability formula to a column formula.
When you do this, 4 columns will be saved to the table.  We're interested in one of the two that say something like Prob[0].
Step 2: This column has an asterisk next to it, click the asterisk and the column properties dialog box will pop up.
Step 3: Remove the "Response Probability" property. No more nifty y-asix box for probabilities.
Step 4: Go the Graph>Profiler, select the column you just modified (e.g. Prob[0]) for the formula. Click the Expand intermediate columns box (super important)
Step 5: Save your awesome new logistic regression figure as interactive HTML (MAC: Export Interactive HTML) and you're good to go.
note: this is for JMP 13, older versions might be different
Method 2: Save Expanded Formulas from the Profiler, Profile Expanded Formula
Step 2: Use Graph>Profiler on one of the Prob columns. Click the Expand Intermediate Columns box (super important)  before clicking OK
Step 3: In the Profiler window, use the red triangle menu to Save Expanded Formulas.
Step 4: Use Graph>Profiler on the Expanded Formula column.
 (thanks to Bill Worley for this tip)
Last Modified: Dec 16, 2016 11:31 AM
Comments
