Benelux JMP Users Group Discussions
Workflow Builder or the "baby steps" into Scripting
Workflow Builder is a new utility to record your JMP data preparation and analysis workflows. It is a way to capture, build, manage, and share your data steps and work without resorting to scripting. Learn how to easily reproduce and recycle an analysis that will save you and your organization precious time.
(view in My Videos)
3 REPLIES 3
hogi
Level XIII
Re: Workflow Builder or the "baby steps" into Scripting
Jmp 18: more options to structure a Workflow:
hogi
Level XIII
Concerning the issue with the Table References, which was discussed in the Q&A
... there seems to be a workaround with Jmp18:
example-of-a-workflow-with-a-for-each-loop.shtml
1) use a workflow step #1 to open/create new tables:
Subset by, open(), Multi File Import ...
2) Select step #1 as Source - Workflow Step in the  FOR EACH settings
3) and add as many workflow steps as you want to the For Each branch:
-> for all steps in the For Each loop, Jmp will use the the tables which were opened in step #1.
[independent of the table name which was used when recording the steps!]
hogi
Level XIII
