Share your analytics insights with fellow JMP users. Submit a brief abstract to the Discovery Europe call for content describing innovative ways you use JMP.
sachinowagh
Level I
msvcp120.dll file missing error (win7 64 bit)
Hello,
I downloaded and installed trial version JMP 12.
After installation the error shwon was "msvcp120.dll" is missing.
Reinstalled and restarted PC but the problem not resolved.
So I googled it and installed program from microsoft website "vcredist_x86"
The problem is not yet resolved.
Is there anything that you can suggest.@
1 ACCEPTED SOLUTION
Accepted Solutions
Re: msvcp120.dll file missing error (win7 64 bit)
Hello,
You are correct with the information found about the Microsoft Visual C++ Redistributables (vcredist_x86) files.  For some reason, that file was not installed during the installation of JMP.  Please try downloading and installing the appropriate redistributables from the following link:
    http://www.microsoft.com/en-us/download/details.aspx?id=40784
For 32-bit Windows, make sure to choose vcredist_x86.exe.
For 64-bit Windows, make sure to choose vcredist_x64.exe.
1 REPLY 1
Hello,
