As of JMP Clinical 17, SAS is no longer apart of JMP Clinical. And as of JMP Clinical 18, installation is completely different and follows the same path as JMP and JMP Pro using my.jmp.com for downloads and a single executable for install.
Paths have changed as well. The install paths and user paths will be similar to JMP and JMP Pro except one will see JMPCLIN as part of the path instead of JMP or JMPPRO.
If JMP Clinical 17 is installed, there is an additional path:
"C:\ProgramData\SAS\JMPClinical\17"
For 18 it is:
"C:\ProgramData\JMP\JMPClinical\18"
@Bob_Hickey, is JMP Clinical packaged the same way as JMP now so one can make package that would include add-ins like JMP?
Chris Kirchberg, M.S.2
www.jmp.com
