JMP is built for discovery, but discovery is not just happening to see something in a graph; it usually involves a lot of work and many process steps.  The problem is that the steps are not always the same in each situation or in each set of data – the analysis has to be interactive. You must be able to pursue clues, identify things, drill down to details, and adapt to new conditions.
The analytic process is fundamentally interactive, and JMP supports interactivity.  But there can be “easy buttons” along the way, and you can create your own “easy buttons” for the steps that you plan to take again.
Whether your work can be planned or is a wild path of exploration and serendipity, JMP has the modes to make your work speedy, efficient and productive, while keeping you in an environment of discovery.
0 Comments
Published on ‎03-25-2024 01:27 PM by Staff | Updated on ‎07-07-2025 12:13 PM
