As the utilization of JSL has expanded, the demand for diverse levels of control and maintenance has grown in tandem. The Add-In Manager has played a significant role in simplifying the management, packaging, and release of numerous add-ins. Given the substantial amount of code now stored in the cloud, a streamlined process has been developed within GitHub utilizing a script built in Python to facilitate effective add-in packaging and deployment.
This presentation delves into the realm of Project JAAB (Just Another Add-In Builder), where the power of GitHub actions is harnessed to automate the packaging and deployment of add-ins. By incorporating essential files from other repositories during the creation of releases, this approach is made even more robust. Through the use of an input-driven Python script and a customizable configuration file, developers have the flexibility to adapt the deployment process to their specific needs. The days of developers grappling with the editing of .jmpcust, metadata, or .def files for each release are now relegated to the past.
But the journey of add-in creation doesn't stop here. The presentation offers a glimpse into what lies ahead, inviting you to explore further. Tune in to learn more about the ongoing evolution of add-in creation and deployment.
We'd  like  to  talk  about taking  a  JAAB  at  add-in  building,
is  what  we're  calling  Project  JAAB.
We're  using  GitHub  actions to  streamline  the  deployment  of  JMP  tools.
A  little  bit  of  overview about  what  we  want  to  talk  about  today
talks  about  the  utilization  of  JSL,
and  it  is  continue  to  expand as  versions  of  JMP  has  come  out.
There  arises  an  increasing  demand
for  better  control and  enhanced  maintenance  of  these  tools
as  more  and  more  tools  are  being  managed to  help  make  people  more  efficient.
Previously  involved  in  this,
there  were  limited  options
that  really  integrated both  the  version  control  aspect  of  it
as  well  as  the  deployment  of  the  add-in.
Entering  Project  JAAB.
Hopefully,  with  this  we  believe it's  going  to  be  a  cutting- edge  initiative
using  GitHub  Actions  to  do  something
that  is  analogous to  what  GitHub  actions  are  intended  for,
but  doesn't  seem  very  common  currently in  their  sphere.
We  hope  this  is  going  to  enable
seamless  packaging and  deployment  of  add-ins,
making  a  diverse,  robust  system to  really  help  out  JSL  coders  everywhere.
In  the  beginning,
the   Add-In Manager really  changed  the  game  for  us.
I  say  that  because  I  had local  source  files  coming  in.
I  then  could  just  simply export  them  to  a  folder
and  come  in  with   Add-In Manager.
This  is  something  that  was  built by  Justin  Chilton,  a  JMP  employee,
and  this  really  streamlined  the  process
because  when  I  use  this  add-in, I  was  able  to  get  a  package  JMP  add-in,
I  was  able  to  get  version  archival, as  well  as  a  network  deployment.
It  would  place  the  add-ins in  specific  network  folders
depending  on  various  metadata surrounding  that  file,
and  also  kept  track   of  what  I  had  published
and  when  I  build  certain  add-ins.
This  really  was  my  primary  go- to  workflow for  a  number  of  years.
This  became  a  little  bit  more  complicated as  we  went  to  the  cloud.
Like  a  lot  of  developers  now,
they're  starting  to  do  more with  things  like  GitHub.
Now  we  have  source  files  in  the  cloud and  GitHub  and  one  or  more  repositories.
Now  we  have  to  download  that  code.
That  code  comes  downloaded  in  a  zip  file.
Those  zip  files  then  have  to  be  extracted into  their  folders.
Then  we  have  to  combine  the  files  together
into  a  singular  folder that  we  want  to  deploy.
Then  we  have  to  delete  any  excessive  files
because  sometimes you'll  get  more  downloaded  with  that  code
than  you  really  want  in  that  final  add-in.
Then  we  can  go  on  to  the   Add-In Manager for  all  of  the  magic  we  mentioned  before.
While  this  workflow  isn't
technically  a  lot  more  complicated than  the  one  we  had  in  the  past,
the  more  add-ins  you  manage,
that  additional  work really  starts  to  add  up.
That's  what  I  was  noticing
when  I  was  shifting  stuff over  into  the  cloud.
This  is  where  I  started  collaborating with  Sage,
who  was  learning  more  about all  the  powers  of  GitHub
and  what  it  could  do  to  maybe  combine both  of  these  worlds  together.
Working  with  Sage, we  came  up  with  the  best  of  all  worlds.
This  is  where  Project  JAAB  comes  in.
Project  JAAB,  we  wanted  to  fit
a  certain  set  of  requirements  in  order to  make  this  completely  successful.
With  an  action  in  GitHub,
we  want  to  trigger when  we  have  a  new  release.
We  wanted  the  action to  package  up  the  repository  code
and  create  the  JMP  add-in  file.
That  package  JMP  add-in  file needs  to  have  additional  files
from  other  repositories  if  it's  desired.
Say,  you  want  to  import  libraries or  something  of  that  similar,
to  the  concept  of  something  like  Python.
We  want  that  JMP  Add-In uploaded  as  an  asset  to  the  repository,
so  that  way  you  have  that  connected traceability  with  your  releases.
You  want  to  automatically  name the  JMP  Add-In  file.
Sometimes  including  the  version and  sometimes  not  including  the  version.
Some  examples  of  this  are  below,
and  they  represent  something that  with  our  infrastructure,
works  with  the  deployment  of  the  add-in,
involving  a  situation  where  people can  get  automatic  updates.
In  those  situations, it's  not  beneficial  to  have
the  actual  name  of  the  add-in changing  every  time  you  have  a  version,
so  it's  better  to  have  that  removed.
But  for  general  sharing,
having  that  version as  part  of  the  file  name
makes  things  a  lot  more  seamless.
Finally,  the  deployment.
Depending  on  your  workflow,
the  deployment  is  reall some  of  the  best  magic
because  this  actually  integrates
into  your  specific  sphere, and  deploys  the  add-in  into  a  folder,
structure,  or  something  like  that,
that  really  supports your  existing  workflows.
An  example  with  what   Add-In Manager  does is  production  releases  get  deployed
into  a  production  folder  and  test  releases get  deployed  into  Test  folder.
You  can  keep  that  separation  still  there.
What  Sage  is  going  to  talk  about with  her  demo
was  primarily  going  to  focus  on  these  here
because  this  is  where the  bulk  of  the  work  gets  done,
and  this  is  the  stuff that  is  most  ransferable
to  anyone  who  is  working  with  JMP  Add-ins.
Secondarily,  we'll  talk  a  little  bit about  the  end,  the  deployment.
As  I  mentioned,  your deployment is  unique  to  your  workflow.
Not  everyone  has  the  same  folder, structures,  the  same  connectivity,
the  same  credentials,
and  all  of  those  things  that  make deployment  potentially  transferable,
but  not  as  seamless as  some  of  the  other  pieces  in  the  demo.
With  that,  I'd  like  to  pass  this  over to  Sage,  who  will  start  the  demo
to  showcase  a  bit  more of  what  we're  talking  about.
Perfect. Thank  you,  Nate.
Let  me  go  ahead and  steal  this  share  screen  from  you.
Let's  see  if  we  can  pick the  right  thing  here.
The  beauty  of  multiple  screens.
All  right,  perfect.
What  you're  seeing  right  here is  just  the  project  JAAB  repo.
As  Nate  was  describing,
I'm  going  to  give  you  an  overlay of  what  this  one  looks  like.
Then  we're  going  to  go  through
and  we're  going  to  actually  build an  add-in.
This  way  you  get  the  ability to  see  with  this  in  action.
This  is  a  look  at  the  project  JMP  repo.
The  brains  of  this  project  actually exist  in  this  AddinB uilder.py,
and  we  will  go  through  this at  the  end  of  the  presentation,
so  I  can  show  you how  the  variables  do  what  they  do.
This  is  the  repo  that  you  would  use to  do  all  of  your  magic.
I'm  going  to  show  you  how  to  use  that.
The  important  thing  here is  this  README  file.
As  I'm  going  through  this  presentation,
if  you  for  some  reason don't  find  this  presentation
or  are  interested  to  just  read  more, the  README  is  a  perfectly  good  place
to  get  an  idea  of  some  of  these  things and  what  they  actually  mean.
It's  the  know- all- place location  to  find  things.
Now  I'm  going  to  go
and  I'm  going  to  actually just  make  an  add-in.
I  think  that  that  makes  sense. It's  a  good  place  to  start.
Here  we're  going  to  build  an  add-in for  this  add-in  that  I  have  for  JMP
called  Daily  Affirmations.
In  this  repo, I  have  my  daily  affirmations  JMP  table,
I  have  my  daily  affirmations  JSL,
and  I  have  my  icon that  I  would  like  to  link  to  my  add-in.
This  is  all  going  to  get  packaged  up into  an  add-in  for  JMP  to  use.
I'm  going  to  go  ahead and  I'm  going  to  go  to  Actions  here.
Inside  Actions,  I'm  going  to  go  ahead
and  I'm  just  going  to  do Configure  a  Simple  Workflow.
In  this  case,  what  GitHub  will  do is  it  will  give  you  a  full  breakdown
of  a  completely  start- from- scratch  action.
In  this  case, if  you  were  to  go  into  the  README,
you  would  see that  there  is  a  usage  section.
What  I'm  going  to  do  is, I'm  actually  just  going  to  come  in  here
and  paste  an  example  of  the  usage  section, and  I'll  just  go  through
each  of  the  pieces, this  way  you  know  what  they  all  mean.
But  in  this  case, this  is  what  talks  to  Project  JAAB
and  says,  "To  make  your  add-in."
In  this  case,  what  we're  doing is  we're  following  what  Nate  described,
which  is  that  when  we  do  a  release,
well,  actually, based  off  of  a  release  published,
that's  when this  action  will  execute.
Then  what  it  does  is  it  builds  the  add-in, and  it  uses  the  Sage  Darling  Project  JAAB
repo  that  I  had  just  shown  you a  second  ago  at  version  1.0.
If  you  decided  that  you  wanted a  different  version  here,  in  this  case,
you  could  change  this to  something  different,
such  as  if  I  had  a  version  2, you  could  do  2  here.
You  could  also  trigger the  main  branch  instead.
You  could  do  at  main  if  you  wanted, which  would  be  the  main  branch
and  would  just  incorporate any  of  my  changes
without  it  being  tied to  a  physical  release.
In  this  case,  I'm  going  to  do  version  1.0
because  that's  the  one that  we  released  and  is  usable.
Also  what's  important  with  actions
is  that  they  come with  what's  called  with  statements.
In  this  case,  we've  got a  few  different with  statements.
This  is  just  for  a  typical  add-in  build.
In  this  case,  I  have  included  a  token.
A  token  is  a  security  measure
that  GitHub  has  that  basically  says, "You  are  who  you  are."
In  this  case,  I've  set  this  up  as  a  secret inside  for   JMP  Discovery.
In  order  to  set  up  your  own  secret,
you  would  go  to  Settings and  set  up  a  secret  in  there.
We  have  also  included  documentation at  the  end  of  this  presentation.
My GitHub  has  put  together  seamlessly to  be  able  to  describe  to  you
how  to  build  your  own  tokens.
Feel  free  to  poke  around  in  there
should  you  be  in  a  situation where  you  have  a  private  repo
to  which  you  need  to  prove  who  you  are in  order  to  actually  execute  any  actions.
Here  we  also  have  our  add-in  ID.
In  this  case,  I'm  calling  this
com. JMP Discoverys . s tarlingd aily Affirmations.
Typically,  this  is  com. Company,  some  name.
You're  seeing  an  example  here.
As  long  as  it's  unique, that's  all  that  really  matters.
Then  add-in  name,
we're  calling  this  daily  affirmations
as  the  add-in  gives  you daily  affirmations.
What  I'm  also  including  here is  what's  called  a  jmpc ust  text  file.
In  this  case,  I  know  that  this  file is  going  to  be  called  jmpc ust.txt .
You  can  call  this  whatever  you  want
as  long  as  the  extension  at  the  end ends  in .t xt.
But  in  this  case, I  know  I'm  making  a  jmpcust .t xt,
I'm  going  to  leave  it  that  way.
I'm  also  going  to  name  my  YAML.
In  this  case, you  can  go  up  here  and  name  it.
You  can  literally  name  this whatever  you  want.
I'm  going  to  call  this  JAAB.y ml to  be  consistent  with  the  action  itself,
but  that  name  just  matters  for  you
for  what  you  would  like to  name  it  for  purposes.
I'm  going  to  go  ahead  and  commit these  changes  to  my  repo,
and  I'm  going  to  say,  Added  Project JAAB  action  to  GitHub  workflows.
Then I'm  going  to  go  ahead and  commit  this  to  the  main  branch.
This  happens  from  time  to  time.
We  love  errors  when  we're  actually doing  stuff,  welcome  to  code.
But  if  I  return  to  the  repository  overview
what  you'll  see  is  that it  actually  got  added  in  anyway.
If  I  were  to  go  into .g ithub/ workflows
and  I  were  to  do  JAAB.yml , you  can  see  that  it  was  actually  added.
I'm  not  quite  sure  why  that  error  comes  up but  I've  seen  it  happen  from  time  to  time.
Definitely  something  worth  looking  into.
But  at  any  rate, it's  actually  added  in  here.
When  I  go  make  my  jmp cust.t xt and  I  go  to  run,
it  will  still  do  what  it  needs  to  do.
Essentially,  it's  just  an  error  saying that,  "Related  to  the  main  branch."
I  must  have  done  something  in  here to  confuse  it.
But  at  any  rate,  it's  in  this  repo, so if  I  were  to  come  in  here,
you  can  see  that  it's  already  been  added to  this  main  branch  anyway.
Now  I'm  going  to  go  into .g ithub/repos,
and  I'm  going  to  go  ahead and  add  a  new  file,  create  a  new  file.
This  is  where  I'm  going  to  make my  jmp cust.t xt  file.
Again,  this  information  is  located in  the  README  for  Project  JAAB,
where  you  can  get  an  idea of  how  to  make these.
There's  also  some  pictures  in  there
relative  to  when you  change  information  in  these,
what  that  actually  looks  like upon  implementation,
should  you  not  be  quite  sure where  things  go.
But  I'm  going  to  go  ahead and  I'll  walk  through  this  as  well.
In  this  case, I'm  going  to  make  for  my  caption
in  my  actual  menu is  going  to  be  JMP  Discovery  2023.
Then  I'm  also  going  to  call  this a  Pick  Me  Up  as  my  menu  items.
You'll  see  this  in  the  menu
in  terms  of  when  I  actually  build this  action  or  this  add-in.
Then  I'm  actually  going to  call  this  Daily  Affirmations.
Then  I've  also  included here the  word  tool  tag.
Don't  edit  this  word.
This  word  is  actually how  the  Python  keys  into
how  to  put  the  version  information into  the  menus.
This  is  way,  people  are  aware of  what  version  number  they're  using.
Tool  tag  is  a  pretty  important part  of  this,
so  make  sure  you  leave  it.
Another  important  part,  the  path  to  which your  actual  JSL  takes  place.
I  know  my  JSL  is  called dailyaffirmations.j sl
because  that's  what's  written  in  my  repo.
Also  here  is  a  ID  called AdDin IDD oN otT ouCHY.
It  says  do  not  touchy  for  a  reason.
Do  not  touchy.
This  just  basically  allows the  Add-in  Builder
to  know  where  to  put that  Add-in  ID  information
so  it  knows  where  to  look  for  it.
But  since  you've  already  put  that as  an  input  in  your  action,
there's  no  reason  to  double  do  it,
especially  since  code  can  find its  way  given  the  right  syntax.
That's  what  it's  going  to  do, it's  going  to  find  its  way  here.
Don't  touch it .
We've  also  added  a  tip  here.
You  are  smart!  You  are  worthy!
We  will  add  that  as  information,
and  I  will  show  you  what  that  looks  like when  you  hover  over  it.
I've  also  added  an  icon  in  here.
As  you  remember, I've  added  an  icon  to  my  repo.
I  know  for  a  fact  I  want  to  use  that  icon for  my  actual  add-in.
In  this  case, I've  edited  this  to  say "p ath,"
and  then  it  also  includes  the  ADDIN_HOME (AdDinIDDoNotTouCHY)\ha ppy.i con.
This  is  a  personal  one.
This  is  because  I  have an  image  I  want  to  use.
You  can  also  here,  instead, do  a  built-in  one,
which  you  can  also  get  an  idea what  the  built-in  icons  are
due  to  an  add-in  that  Justin  also  made.
I'll  add  Justin  for  another  great  add-in that  we  can  use.
But  here  we're  going  to  do an  icon- type  path.
The  README  also  has  a  description on  how  to  use  built-in  ones,
should  that  be  what  you  would  prefer.
I'm  going  to  go  ahead and  commit  these  changes  as  well.
I'm  going  to  say  added  jmp cust.t xt.
I'm  going  to  commit  this to  the  main  branch.
Now  you  can  see  that  this has  also  been  committed  in  here.
This  jmp cust.t xt has  to  be  in  the  workflows  area
for  Project  JMP  to  find  it.
Just  make  sure  that  you  are  in  this  folder should  you  decide  that  you  want  to  search.
It  is  in  this  folder,  so  this  way, Project  JMP  can  find  it.
Just  make  sure  this  is  where  it's  located,
or  else  it  will  not  be  able  to  find  it and  you  will  get  an  error.
Now  I'm  going  to  go  back to  daily- affirmations  in my  repo.
I  think  it's  time to  build  a  release  candidate.
What  we're  going  to  do, I'm  going  to  go  into  Create  a  new  release,
and  I'm  going  to  choose  a  tag, and  I'm  going  to  go  v1.O.O  RC 1.
There  is  also  version  information inside  the  README,
should  you  need  more  context on  how  this  actually  works.
But  essentially  what  we're  doing  here is  we're  saying  V  for  version.
This  is  not  technically  necessary.
If  you  do  not  want  to  have  it  there, feel  free  to  get  rid  of  it.
Just  don't  put  anything  else at  the  beginning.
Don't  put  R,  don't  put  something  else.
It  will  end  up  causing  an  error  code.
Followed  by,  you  can  put as  many  zeros  as  you  want  here,
as  long  as  the  digits are  spaced  by  a  period
or  a  period  is  in  between  the  numbers, no  spaces.
You  can  also  not  do  things like  underscores  or  slashes.
You  will  just  want  to  make  sure that  you  put  these  together  as  1.0.0.
You  could  also  keep  going  .0.0.0.0 to  your  heart's  content.
But  in  this  case, we're  going  to  use  three  digits.
Another  option  is  you  could  actually make  it  shorter.
You  could  do  1.0  if  you  wanted, as  you  saw  in  my  Project  JAAB  repo.
But  in  this  case,  we're  going  to  do  1.0.0.
Then  we're  also  including  an  RC  here, which  stands  for  Release  Candidate.
Project  JAAB  supports  release  candidate.
It  supports  beta  and  it  supports  alpha, designated  by  a  dash  here.
Also  of  note  is  that  you  want  to  make  sure that  you  include  the  one  at  the  end  here.
Don't  just  cleave  off  any  number.
You  want  to  make  sure  that  Project  JAAB
knows  that  you're  doing a  release  candidate  and  what  number  it  is.
In  this  case,  we're  going  to  put  one  here
because  that's  the  number that  we're  starting  with.
But  you  can  go as  high  numbers  as  you  want  here.
I'm  going  to  go  ahead  and  say, Create  a  new  tag.
Then  I'm  going  to  say,  Generate  release  notes,
which  will  go  through and  pull  the  entire  commit  log
relative  to  this  before  this  release.
Then  I'm  going  to  say, P ublish  release.
You  can  also  add  in  more  information there  should  you  choose.
Now  what  GitHub  is  going  to  do
is  it's  going  to  take all  those  packages  together
and  it's  going  to  run  that  action.
If  I  were  to  go  into  Actions  here,
you'll  be  able  to  see  that  this is  queuing  up  what  GitHub  calls  as  Queued.
You  can  see that  it's  thinking  for  a  little  bit.
You  get  this  fancy  yellow  circle.
Then  over  the  course  of  about  15  seconds, you  now  get  your  completed  version
with  this  nice  blue  checkmark, which  feels  really  nice.
If  this  were  to  fail,  this  is  next, which  does  not  feel  as  nice.
In  that  case,  you  can  see that  this  is  actually  completed.
I'm  going  to  go  into  this  version.
This  way  you  can  just  see what  the  action  spits  out  for  information.
If  I  go  to  build- addin
and  I  go  into  the  example  Addin  Build with  Project  JAAB  and  I  open  this  up,
you  can  see  that  it  was  running from  this  repo  at  this  version.
It  ran  this  Python  code, which  we'll  go  through  in  a  little  bit.
Then  it  tells  you  information relative  to  what  you  put  in  for  inputs.
In  my  case,  I  put  in  RC, so  it's  a  release  candidate.
It  says  that  this  is  a  release  candidate and  thus  it  will  be  deployed  in  testing.
It  also  tells  you  the  addin  build,
which  is  complete for  what  the  addin  version  is.
I  included  the  tool  tag  here, so  you  can  see,  as  Nate  had  described,
with  the  tool  tags  being  added  on.
This  is  an  example  of  that  taking  place.
Then  it'll  tell  you  that at  the  completion  of  the  job,
it  is  uploaded  to  Git.
We're  going  to  go and  we're  going  to  download  it.
If  I  go  over  to  Code and  I  go  over  to  Releases,
you  can  see  that  included  here  now in  the  Assets  section
is  this  dailyA ffirmations and  then  the  version  number
that  we  had  put  in when  we  built  the  release.
Now  what  you  can  do  is you  can  download  it.
That's  what  I'm  going  to  do.
Download  it  and  then  I'm  going  to  open  it and  then  I'm  going  to  install  it.
Now  that  I've  installed  it because  it  happened  super  quickly,
there  is  a  JMP  Discovery  2023  here.
This  was  not  here  before.
Now  if  I  were  to  click  this and  you  can  see  A  Pick  Me  Up!
Which  is  what  we  had  written in  the  jmpcust.t xt  file,
and  then  Daily  Affirmations, and  then  the  version,  V1.0.0  RC 1
is  linked  to  this  location.
Then  you  can  also  see  the  caption  here.
You  are  smart!  You  are  worthy! Came  up  from  the  jmpcust.t xt  file.
This  is  an  example  of  this being  pulled  through.
Now  what  I'm  going  to  do is  I'm  actually  going  to  open  the  files.
This  way  I  can  demonstrate what's  actually  inside  of  these.
In  this  case, the  project  JAAB  went  through
and  built  in  the  add-in.d ef  file.
It  went  in  and  built  in the  addin.j mpcust  file.
It  also  included  those  three  files
that  were  located  in  the  repo
in  order  for  us to  be  able  to  build  the  add-in.
These  are  just  the  generic  things that  get  built- in
when  you  don't  have  anything  added like  metafiles  or  anything  like  that.
For  our  next  version, I'm  going  to  go  in
and  I'm  going  to  show  you how  to  add  in  the  metafiles.
Should  you  want  to  do  metafiles
you  don't  necessarily  have  to for  production  releases,
but  I'm  going  to  link  them  both for  an  effort  to  be  continuous.
We  will  do  our  production  release and  what  that  looks  like.
Then  we  will  also  add  in the  meta file  information.
This  way  we're  consistent with  showing  those  two  steps,
but  you  don't  necessarily have  to  do  them  in  tandem.
These  are  our  files  that  are  located  here.
What  I'm  going  to  do  is,  now  is  the  time to  go  through  and  do  a  production  release.
I'm  going  to  go  ahead and  I'm  going  to  go  back  over  to  Code.
I  know  for  a  fact  there's  nothing about  this  code  that  I  want  to  change.
Oh,  I  forgot,  I  didn't  even  run  this.
You  should  see  what  it  looks  like when  you  run  this.
If  I  click  this, you  get  a  key  little  window
that  tells  you  some  positive  affirmation.
In  this  case,  "Negative  people  need  drama like  it's  oxygen.
Stay  positive  and  analyze  this  data!
This  is  what  the  add-in actually  does  when  you  execute  it.
But  now  I  know  that  when  I  execute  this, everything's  working  flawlessly.
I  know  for  a  fact that  now  it's  ready  for  production.
That's  what  we're  going  to  do  is we're  going  to  launch  it  into  production.
I'm  going  to  go  back into  GitHub  Workflows.
I'm  going  to  go  into  the  .y ml.
I'm  going  to  edit  this.
I'm  going  to  go  ahead  and  I'm  going to  add  a  little  bit  more  notes
to  the  bottom  of  this.
Which  is  that  I  would  like  to  add  in my  making  of  the  meta file.
We're  going  to  make  our  metafile, which  is  what's  set  as  true  here.
This  is  typically  set  to  false,
which  is  why  I  didn't  have  to  add  this  in as  a  input  before.
But  in  this  case, I  want  to  make  a  metafile.
Again,  this  isn't  necessarily  linked
to  publishing  add-ins for  production  release,
but  in  this  case,  I  want  to  show what  that  looks  like
when  it's  actually  inside  of  the  add-in.
The  pub  names,  this  is  the  actual  name of  the  published  list  add-ins.
In  this  case, I'm  showing  those  pubaddins.j sl.
This  is  what  gets  edited when  you   actually  deploy.
In  this  case, I'm  just  showing   as  pub  add-ins.
Typically,  it's  called  publish  addins,
but it is  actually  default to  publish  addins,
but  in  this  case,  I'm  overriding  it just  to  show  an  example
so when  I  show  you  the  meta file, you  can  see  what's  written.
This  is  the  final  pub  paths.
This  is  where  the  actual  add-in is  being  published.
Again,  this  gets  written into  the  meta file  information.
This  is  how  you  would  put  it  in  for  syntax
relative  to  putting  that into  the  actual  add-in.
I'm  also  going  to  exclude the  tag  suffix  here  for  production  release
and  to  show  that  when  you  exclude the  tag  suffix,
it  no  longer   included  into  that  file when  it  gets  added  as  an  asset.
That's  that.
I'm  going  to  go  ahead and  commit  these  changes.
I'm  going  to  say  added  some  inputs for  metafile  and  tag  suffix  removal.
Then  I'm  going  to  go  back  to  Code.
We're  going  to  go  to  Releases, and  I'm  now  going  to  draft  a  new  release.
In  this  case, I'm  going  to  do  version  1.0.0.
I'm  going  to  go  ahead and  again  generate  release  notes.
Then  I'm  going  to  go  ahead and  say  Publish.
In  this  case,  I  cleaved  off  the  -RC 1
because  I  know this  is  a  production  release.
I  know  I'm  ready  to  put  this into  production  mode
by  cleaving  off any  release  candidate  alpha  or  beta
that  makes  it  this  way.
It  sees  it  as  a  production  release.
In  this  case,  I'm  doing  the  version that's  actually  a  production  release
and  not  some  release  candidate related  to  it,
which  is  why  it's  the  same  code.
Then  if  I  go  over  to  Actions  again,
you  can  see  this  is  already  completed in  a  cool  15  seconds.
Again,  when  I  go  back into  this  build- addin  information,
the  difference  is  that  you're  going  to  see is  that  the  custom  metadata
has  been  written  to  the  file  location,
so  you  know  that that  got  written  in  there.
You  also  know  that  this  release is  a  production  release
and  will  be  deployed  in  production.
It'll  show  you  those  locations  as  well.
Now  if  I  go  back  and  I  go  back  to  Releases and  I  go  ahead  and  I  click  this,
you  can  see  that  this  no  longer  has the  tool  tag  at  the  end  of  it,
which   the  tag  suffix  takes  away.
If  I  go  ahead  and  click  this, now  it's  ready  for  download.
I  go  ahead  and  open  it, I  install  it.
Now  you  can  see  that the  JMP  Discovery  2023  stayed  the  same.
The  Pick  Me  Up!  has  also  stayed  the  same,
but  now  you  can  see  that it's  Daily A ffirmations  version  1.0.0
and  no  longer  release  candidate  one,
where  the  add- in  itself has  not  changed  at  all.
It  still  executes  the  same  way.
It's  just  changed  the  version  information.
This  way  you're  aware  of  what  version that person is on  and  as  they  are  as  well.
Then  you  can  get  some  fancy  quote with  the  daily  affirmations.
That's  that.
That's  an  example of  building an  add-in  with  Project  JAAB
related  to  this  type  of  action, related  to  this  type  of  repo  as  well.
What  I'm  going  to  do  now  is  I'm  actually just  going  to  jump  into  the  repo  itself
and  give  an  idea  behind  the  brains of  what  the  Add-In  Builder  actually  is,
in  order  to  show  some  of  the  information related  to  what  drives  this  action.
The  AddinB uilder.p y  is  what the most of  the  brains  of  this  project  is.
You  can  see that  there's  Python  in  here  as  well.
You're  welcome  to  take  a  gander  at  this at  your  leisure
if  you  find  reading  code  interesting.
There's  a  bunch of  different  support  functions  here,
the  real  brains  of  how  this  actually  works is  this  json_out  function,
which  actually  connects  to  the  GitHub  API in  order  to  get  the  information
for  your  action  and  for  your  repo.
This  also  has  an  example, usually  just  the  json_out  function,
so  you  can  see  what  the  actual  output  is and  what  you'd  be  targeting.
Then  at  the  end,  the  very,  very  end,
which  I'm  going  to  scroll  super  quick because  there's  a  lot  of  code  here,
at  the  very  end, there  is  this  environmental  variables,
which  is  how  you  actually get  passed  in  from  GitHub.
When  you  put  in  your  inputs
like  we  had  just  done  with  the  action in  the  Width  section,
this  gets  pulled  in  from  that  action in  that  environment
to  then  get  passed into  this  Python  script.
This  is  how  these  variables  are  connected.
You  can  go  ahead and  take  a  look  at  this  full  flow
and  see  how  all  that  translates to  build  the  add-in.
But  that's  the  brains of  how  this  actually  works
and  how  the  variables are  passed  in  between  the  two.
Last  but  certainly  not  least  is  that this  is  an  ever growing  code  base.
It  is  open  to  you.
The  repo  is  available for  you  to  take  gander at,
for  you  to  use  at  your  leisure.
But  also  we're  looking  for  feedback
and  anything  else  that  you  feel would  be  necessary  for  growth  here.
If  that's  the  case and  you  have  something  you  want  to  say,
you  can  either  shoot  us  a  message, either  Nate  or  I
and  our  contact  information is at  the  end  of  the  presentation.
Or  you  can  also  go into  the  Issue  section  here  in  GitHub,
of  which  you  can  actually  say  N ew  issue,
and  you're  welcome  to  put  any  information
that  you  think  would  be  great for  bug  fixes,
or  anything  else  that  would  be  helpful for  adding  in  more  information
for  the  actual  creating  of  this to  make  this  more  intricate  and  seamless.
That's  that.
The  last  step  of  this is  obviously  deployment,
which  is  not  included in  Project  JMP  in  this  case,
and  that's because  we  have  a  very  specific IDEXX  infrastructure  for  how  that  works.
But  I'm  going  to  let  Nate talk  a  little  bit  about  that.
We  would  actually  love  to  hear more  information  from  anybody  else
about  deployment or  talking  further  into  it.
I  will  let  Nate  cover the  deployment  section
for  how  we  do  it  here  at  IDEXX.
Sounds  great,  Sage.
Thank  you  very  much  as  I  pull  this  up.
As  she  mentioned,  the  last  step in  the  process  is  deployment,
and  it  is  very  unique to  individual  organizations.
But  a  little  bit  about  how  we  do  it  is
we  have  the  step  where  we  pull all  of  our  stuff  in  GitHub
the  way  Sage  had  described,
utilizing  some  of  the  additional  inputs she  talked  about  for  that  release,
like  the  creation  of  the  metadata  file, some  of  the  tool  tag  stuff.
That  all  fits  also  into  what  then  goes
into  a  runner  that  runs on  a  local  computer  here  at  IDEXX
in  order  to  seamlessly  connect into  our  network  infrastructure.
There's  a  link  at  the  bottom as  well  as  the  end  of  the  presentation
talking  about  self  hosted  runners.
Everything  Sage  talked  about was  hosted  directly  on  GitHub  runners
as  opposed  to  something  done  locally.
Also  on  our  local  computer  here  at  IDEXX,
we  have  a  Python  that  gathers  inputs and  retrieves  the  JMP  add-in,
all  very  similar  to  what  Sage  had  just  talked  about.
But  the  tail  end  of  that actually  takes  that  add- in
and  it  deploys  the  add-in to  a  folder  structure,
that  can  then  be  synced
to  whatever  network  capability we  need  in  our  system.
For  instance,  production  JMP  Add-Ins go  into  the  production  folder,
test  goes  into  a  test  folder,  etc.
In  addition,  it  also  updates
what  would  be  called the  published  addin  info  file.
I  think  pub  addins is  what  Sage  called  it  in  her  example.
Having  that  information  in  the  metafile,
correlates  to  using the  published  add-in  file
if  you  want  to  do  something like  automatic  updates,
because  then  it  syncs  the  information and  tells  other  functions  where  to  look
in  order  to  execute  those  pieces.
Again,  we  would  love  to  discuss this  more  with  people
to  see  how  they  may  want  to  implement  it, because  this  is  very  unique,
but  I  think  it  offers  them really  unique  options
for  people  to  bring into  their  own  company  infrastructures.
That  takes  care  of  the  bulk  of  everything we  wanted  to  talk  about  today.
I  think  at  the  end of  the  presentation  here,  we  discussed…
Here's  a  very  simple list  of  links.
This  is  also  available as  a  standalone  file
with  the  uploaded  presentation.
If  you  would  like  to  get  in  touch  with  us
other  than  through  the  Issues  section of  the  Action,
you  can  contact  us  through  email, GitHub,  LinkedIn.
We're  also  both  on  the  JMP  Community.
Here  is  my  information and  here  is  Sage's  information.
Please  feel  free  to  reach  out.
I  believe  also  you'll  be  able to  have  a  comment  thread  running
on  the  on- demand  website  as  well.
Lots  of  ways  to  get  in  touch and  have  a  really  good  discussion
about  everything  we  want  to  talk  about.
With  that,  I  think  we  are  done with  the  presentation.
We  look  forward to  everything  you  have  to  say.
I  guess,  happy  JAABing.
Have  fun  JAABing.
Published on ‎03-25-2024 04:55 PM by | Updated on ‎04-01-2024 01:47 PM
In  the  beginning,
All  right,  perfect.
Now  I'm  going  to  go
Then  add-in  name,
Do  not  touchy.
Don't  touch it .
That's  that.
That's  that.
It  is  open  to  you.
That's  that.
Sounds  great,  Sage.
Have  fun  JAABing.
